Hello...
Just purchased to day the PRO version and attempted using it with my new Numark Omni Control, but I'm not satisfied by the skins available. I would need one more suitable for use with that interface, combining the options of at least a couple of the VDJ 6 Standard skins already available.
Anyone willing to provide some help? I would be extremely thankful...
Thanks in advance
ciao
Giorgio
Thanks in advance
ciao
Giorgio
Posted Wed 08 Jul 09 @ 12:16 pm
say what you need :) i think than somebody can help you to design one or can say how you add some features to a skin to do a mod.
I use this one
http://www.virtualdj.com/forums/112162/Virtual_DJ_Skins/CUE_RMX_by_cioce_(1280x768)_v2_0_beta_-_Help_me_with_the_new_skin_engine_please.html
with my hercules i think theres very much in it what do you need more ?
I use this one
Posted Fri 10 Jul 09 @ 3:15 am
Ok.... basically, in a perfect world, what I would need is.
1) The basic layout of VDJ6 "Internal Mixer" standard skin...
2) ...with the look and feel of a Numark Omni Control...
3) ...widescreen (or 1280x800)...
4) ...with the "4 Bar Dual Progress Indicator" which can be found on top of VDJ6 "Widescreen" standard skin.
That's it. It doesn't appear as an impossible mission to me, but I downloaded the Skin Creator and got immediately scared by it... :)
Posted Fri 10 Jul 09 @ 3:20 am
1) Already in my skin
2) Ok but layout of my skin is not so different
3) Already in my skin
4) Already in my skin
Posted Fri 10 Jul 09 @ 3:27 am
...then I definitely need to test it asap... ;)
Posted Fri 10 Jul 09 @ 3:33 am
