Did anyone ever successfully convert this to 1280x1024?
Posted Fri 10 Jul 09 @ 4:58 pm
This is the step by step process to resize the skin to 1280x1024:
1. Open the XML file for the skin
2. Select 1280 as output width and click on the "x" between output width and height
3. Use "Simple Resize" option and resize the skin.
4. Once the first resize is done, in the menu, click on "Use previous resized skin"
5. Select 1280x1024 as output size
6. Use "Browser resize" option
7. Resize the skin
Before doing all this, make sure you downloaded the latest version of the Skin Resizer Tool (version 2.1.1)
http://www.virtualdj.com/addons/7187/Skin_Resizer_Tool.html
7. Resize the skin
Posted Sat 11 Jul 09 @ 4:58 am
I'm having a slightly different problem.
I just hit the padlock while it's playing and now it's locked...
How do I unlock it?
I'm on MAC btw.
Ross
How do I unlock it?
I'm on MAC btw.
Ross
Posted Sat 11 Jul 09 @ 12:59 pm
arhh problem solved thanks for everybodys hellp lol
just wondering though what are the skip 8+ beats and skip 8- beats called when im mapping them to a midi contoller?
Posted Tue 14 Jul 09 @ 6:28 am
The skip beats are:
goto +8
goto -8
goto +8
goto -8
Posted Tue 14 Jul 09 @ 11:28 am
whie im djing ive founda few errors,
1. the cue buttons will not always overwright each other. (say i want to change the cue i have 2 delete it first then cue it again)
2. the mid high and low crossfaders get stuck and the kill switches get stuck (as in when i cross the low over to the other track it dosnt always change the fader moves but theres still bass from the other side)
other then that its good havnt tried many of the other button like smapler and effects yet
i dont no if its because i changed the size to 1280 x 800 or the version i have is no the latest
HELP!!
HELP!!
Posted Thu 16 Jul 09 @ 10:41 pm
Can't understand anything...
Posted Tue 21 Jul 09 @ 11:15 am
The low Crossfader Dosnt work when i go from 1 side to the other i guess i will have to work around it and get to no the functions of this skin
Posted Wed 22 Jul 09 @ 3:15 am
Check it again, it's working well for me...
Posted Thu 23 Jul 09 @ 8:54 am
Is there any other way to unlock it, I'm on 1400x900 and can't see the email address at the bottom of the skin!
Posted Wed 12 Aug 09 @ 7:21 pm
Go to the Config pannel then go to the shortcut tab.
Create a shortcut with the syntax: skin_pannel "unlocked" on
Then close the config pannel and press the shortcut you've just created and... tadaa ! it's unlocked !
Posted Wed 19 Aug 09 @ 9:49 pm
