I have encountered only 1 problem with my dn-s3700's. Of the two units i have, one of them the platter doesn't seem to operate correctly. The platter spins as i should, but when i go to scratch with it, the software does not respond at all. If i change the platter to jog mode however, it works just fine. This is only on one of the players and the other players works 100% fine.
Any suggestions?
-PZ
Any suggestions?
-PZ
Posted Thu 04 Jun 09 @ 7:42 am
Download the latest fix - v6.0.1
Make sure you leave the controllers in their factory defaults for the MIDI Channels - both on channel 0.
Posted Thu 04 Jun 09 @ 9:45 am
cstoll
Im having the say problem i upgraded to 6.0.1 both 3700's are factory defaults...
but whats crazy things is that when i start with the right player the platter is fine (scratch)
once i start the left player (its 100% goods) the right player platter stops working meaning can't scratch (but still spinning)(no responce at all)
i half to que to stop or pause... then i que a song (start) again platter moves song starts but the platter has no responce...
if i start the left player 1st the right dose the same thing ((can't scratch) (but still spinning)(no responce at all))
this is everytime
and right before i post this my putter lock for the 1st time ever vdj did not responce
had to end process in task mgr.
this is everytime
Posted Thu 04 Jun 09 @ 1:56 pm
any help on this issue...
Posted Fri 05 Jun 09 @ 9:31 am
Cali - check here .. http://www.virtualdj.com/forums/109913/Hardware_Technical_Support/Denon_DN-S3700_and_problems_with_VDJ6_.html?search=3700&page=1
And I am going to lock this thread and let's continue the conversations it that one ...
Topic Locked
Topic Locked
Posted Fri 05 Jun 09 @ 9:40 am
