I use Hercules MK2 and in my previous version I was able to expand and collapse folder with the right & left (load keys) when I navigate to the browser window but since i installed v6 that feature is no longer availabe.
How can I get this to work? Is there anyway of modifying the mapper to get this feature?
Posted Thu 04 Jun 09 @ 2:29 am
Seems as if no one here can help me out on this one. I will try and send a ticket for it. Hopefully I might get a response.
Cheers
Cheers
Posted Thu 04 Jun 09 @ 8:23 am
You need to change the functions for the Left and Right buttons... change the LOAD key action in the mapper to -> browser_folder
Posted Thu 04 Jun 09 @ 9:49 am
Thank you.
I made the changes and the load keys expands and collapse the folders in the left window but the load song to deck action in the right window is now disabled. It used to work that way in my previous version. I guess I need to map the load keys action as "browser_folder" for the left window and "load_songs" for the right window but I haven't got a clue how to do that.
Posted Thu 04 Jun 09 @ 3:55 pm
Use this then ->> browser_window "folders" ? browser_folder : load
Posted Thu 04 Jun 09 @ 5:50 pm
