I have a dedicated labtop that i use for only VDJ and BCD2000. i havent had any problem with it until i upgrades to VDJ6. Now the jog wheel only goes forward. i dosent matter what way you cratch, the song just plays forward or fast forward.
You cannot reverse the song by turning the jog wheel Anti clockwise.
Any help will be highly appreciated
Posted Mon 01 Jun 09 @ 4:41 pm
Please see your e-Ticket ...
Posted Mon 01 Jun 09 @ 7:28 pm
I have the same problem with my DjConsole! How i can fix this???
Posted Tue 02 Jun 09 @ 6:27 am
http://www.virtualdj.com/addons/2170/Registry_Tool.html
And disable VinylMode
Posted Tue 02 Jun 09 @ 7:28 am
hi, i have bcd2000 and i have same problem, i did djcell registry tool disable vinyl mode, but it doesnt fix the problem, the jog goes only forward.
Posted Tue 02 Jun 09 @ 9:43 am
What has atomix done...
I have the same issue with the ICDX.
You can only turn it back if you turn it forward first, then it will allow you to turn it back.
This has got to be changed. How are you suposto scratch and beat juggle?????
Posted Tue 02 Jun 09 @ 10:49 am
Do not double/multi post ... you made your case ... it's being looked into .. and your issue is not the same as this one.
BCD200 doesn't have touch sensitive jogs ...
Posted Tue 02 Jun 09 @ 11:01 am
i have pressure sensitive jiogs...
Posted Tue 02 Jun 09 @ 11:03 am
I know the BCD doesn't and you hijacked this thread with a different issue ...
Posted Tue 02 Jun 09 @ 11:08 am
its similar man. but if you tell me my issue is being locked into as i reported it in another thread, shouldnt any of the mods notify me of that instead of just viewing my thread and not commenting?
A lot of times no one notifies us that its being looked into and we get shit on for double posting.
Posted Tue 02 Jun 09 @ 11:13 am
as well i just bought VDJ 6 a few hours ago via CC online. Can i get a refund? Im going to stick to cue 5.2.1 as this is unusable. If you say no refund is allowed, then ths should be fixed, as its missleading. I can record a demo to show you what im refering too. I just tried it in cue 5.2.1 again and it dosent compare.
Posted Tue 02 Jun 09 @ 11:15 am
I am the one dealing with all the comments here about controllers and v6.
Posted Tue 02 Jun 09 @ 11:39 am
hi , find a solution, run angular momentum vsti (for bcd2000), can download from here : http://amvst.com/index.php?name=Downloads&file=details&id=31 ,select bcd2000 as input and port 1 and 2 output, then i can use simple midi wrapper in vdj6 config, where i config deck1 jog_wheel -0.01 in occ19 and deck2 jog_wheel -0.01 in 0cc18 (backward) and then in behringerbcd2000 : +0.01 (forward).this is for bcd2000 and vdj6.
Posted Tue 02 Jun 09 @ 11:58 pm
Download this tool ..http://www.virtualdj.com/download/miditrace.exe
Run it by itself with VirtualDJ closed ...
You should see the bcd listed on the right if not by name .. maybe USB Audio ...
Highlight it in both boxes. Then just gently with the left jog go to the left rotation (should see some codes display) then go back to the right.
Just need a few codes to the left then to the right ... but if you could paste the results here ... it will help .. thanks.
Posted Wed 03 Jun 09 @ 9:08 am
Left Jogwheel
Left - B0 13 40 00
Right - B0 13 41 00
Right Jogwheel
Left - B0 12 40 00
Right - B0 12 41 00
Left - B0 13 40 00
Right - B0 13 41 00
Right Jogwheel
Left - B0 12 40 00
Right - B0 12 41 00
Posted Wed 03 Jun 09 @ 4:32 pm
cstoll, just letting you know if you dont already is that version 6.0.1 still does not fix the jog wheel issue for the bcd 2000
Cheers
Kaoz
Cheers
Kaoz
Posted Fri 05 Jun 09 @ 12:12 am
thanks
Posted Tue 09 Jun 09 @ 9:41 pm
Any solution with the BCD2000 jog wheel and VDj 6.1 ?
Posted Fri 12 Jun 09 @ 3:26 am
It is being reworked - both 2000 and 3000 controllers....
Posted Fri 12 Jun 09 @ 9:59 am
ok
Posted Fri 12 Jun 09 @ 4:51 pm
