Forum: Old versions
Topic: Crashgaurd.txt need help asap for job...
ok so im guessing my saved cue points are F***ed but i at least need to be able to play ill worry about that later this is later
i have no idea whats goin on.. one day it worked next day it didnt i tryed doing a system restore but didnt work, what do i need to do to fix my problem
Crash ID=00cf0000 (date=905062351, version=5.2 Pro, build=520, thread=Main, dump=00000000, excode=c0000005 (1,2))
Crash ID=00cf0000 (date=905062352, version=5.2 Pro, build=520, thread=Main, dump=00000000, excode=c0000005 (1,2))
Crash ID=01160005 (date=905070014, version=5.2 Pro, build=520, thread=Main, dump=003a0020, excode=c0000005 (1,0))
Crash ID=011d0003 (date=905070014, version=5.2 Pro, build=520, thread=Main, dump=0249d86e, excode=c0000005 (0,7aaadeb9))
Crash ID=011d0003 (date=905070014, version=5.2 Pro, build=520, thread=Main, dump=0249d86e, excode=c0000005 (0,ba85b98))
Crash ID=02ff0000 (date=905071934, version=5.2 Pro, build=520, thread=Main, dump=6d006d00, excode=c0000096)
Crash ID=03060000 (date=905071934, version=5.2 Pro, build=520, thread=Main, dump=6d006d00, excode=c0000096)
Crash ID=02ff0001 (date=905071934, version=5.2 Pro, build=520, thread=Main, dump=00000006, excode=c0000005 (1,2))
Crash ID=03060000 (date=905071934, version=5.2 Pro, build=520, thread=Main, dump=69007400, excode=c0000005 (0,2))
Crash ID=02ff000a (date=905071936, version=5.2 Pro, build=520, thread=Main, dump=6f007200, excode=c0000096)
Posted Thu 07 May 09 @ 7:11 pm
cstollPRO InfinityMember since 2004
All of those crashes are external to VirtualDJ ... which means there is something wrong with your system. Hardware failing, Video drivers, Sound drivers, conflicting IRQs, O/S corruption, etc.
** Also, once you resolve your system issues, it might help if you were using a licensed version as well.
Posted Thu 07 May 09 @ 9:29 pm
damn how can i figure out what my actual hardware problem is? i just signed up i havent registered yet
Posted Fri 08 May 09 @ 1:22 pm
taylaPRO InfinityMember since 2007
try uninstalling and reinstalling with a fresh trial version may help...
Posted Fri 08 May 09 @ 4:42 pm
