GTDaudio GTD-750 Power Amp Review.
Specs
◆ 1500 Watts RMS @ 8 Ohm Bridged Mono
◆ 2 X 2250 Watts RMS @ 2 Ohms
◆ 2 X 1250 Watts RMS @ 4 Ohms
◆ 2 X 750 Watts RMS @ 8 Ohms
◆ Inputs: 1/4", XLR ,
◆ Outputs: Banana Binding Post, Speakons
◆ Left / Right Level Controls
◆ Dual Fan cooling System
◆ Ground Lift
◆ Protect LED
◆ Peak LED
◆ Rack Mountable
◆ Power Supply: 110 Volt
◆ Dimensions ( W x H x D ) 19" x 4" x 17"
◆ Weight: 48 lbs
First impressions
The amp is moderately heavy for an amp with these specifications it has a solid aluminum front plate and steel case. Fit and finish is quite good nothing feels loose. Overall the amp does not feel cheap.
Front face has all the normal buttons and meters you would find on a pro power amp. Power rocker switch left and right gain controls and signa.l power and clip leds.
On the back it has XLR and TSR inputs a ground lift switch varable high pass filters and switches for each channel a gain switch stereo mono and bridge switch and to round it off speakon and banana plug speaker outputs.
Installed the beast into my rack and ran it full range first. It is a quiet amp no hiss or hum when no signal applied. Running full range the amp was very neutral. I plays much louder than my Carver but my Carver is half the power output. Set it up as a sub amp and here is where it shines it controls my subs well and never seems to run out of power. I played both 2 and 4 subs with this amp and it handled it with ease. It draws cool air from the back and forces it out the front keeping the other stuff in your rack away from warm air.
Conclusion
Fit and finish 9/10
Ease of use 10/10
Sound quality 9/10
Weight 7/10 (a bit heavy)
Price/Value 9/10
This amp cost me $360 Canadian dollars shipped. For those in the US it is $249 US shipped.
http://www.gtdaudio.net/popup_add_image.php?imagesID=65&osCsid=a92166f0273b7bdc910f6bbefc8587af&products_id=56&cPath=33
Specs
◆ Ground Lift
◆ Protect LED
◆ Peak LED
◆ Rack Mountable
◆ Weight: 48 lbs
First impressions
Conclusion
Fit and finish 9/10
Ease of use 10/10
Sound quality 9/10
Price/Value 9/10
Posted Tue 14 Apr 09 @ 7:16 pm
750 per channel for 8ohms??? thats CRAZY for that price range....
maybe i should drop 300 for it...
Posted Tue 14 Apr 09 @ 9:19 pm
Damn I just don't know about this one man it sounds to good for me. But i just may give it a try one day
Posted Wed 15 Apr 09 @ 4:43 am
Here are the nudes.... Very clean and organized The transformar is almost as big as my head.
Posted Wed 15 Apr 09 @ 9:30 pm
NICE
THANK YOU SIR
THANK YOU SIR
Posted Thu 16 Apr 09 @ 2:01 am
