Crash ID=00428e55 (date=902231259, version=5.2.1 Pro, build=521, thread=Scan, dump=8934823b, excode=c0000005 (1,4))
Crash ID=00428e55 (date=902250010, version=5.2.1 Pro, build=521, thread=Scan, dump=8934823b, excode=c0000005 (1,4))
Crash ID=00428e55 (date=902270102, version=5.2.1 Pro, build=521, thread=Scan, dump=8934823b, excode=c0000005 (1,4))
Crash ID=00428e55 (date=903040143, version=5.2.1 Pro, build=521, thread=Scan, dump=8934823b, excode=c0000005 (1,4))
Crash ID=00428e55 (date=903070341, version=5.2.1 Pro, build=521, thread=Scan, dump=8934823b, excode=c0000005 (1,4))
running tccd,video mixing
toshiba dual core x64 running vista x64os
4gb ram
1tb wd mybook
sl1/maya44usb(depends..vdj dont really like my sl1 too much lol)
edirol um3 midi to usb
i notice when i try to scratch one video the other freezes til i stop scratchin ,,it didnt do this b4
also random crashes and dissapearing vdj
i think its narrowing to either timecodes/asio or /and the edirol um3 midi to usb
4gb ram
1tb wd mybook
Posted Tue 10 Mar 09 @ 2:57 pm
can someone give me a clue to reading crashguards..
Posted Tue 10 Mar 09 @ 6:59 pm
Only djcel know how rendering those numbers.
Posted Tue 10 Mar 09 @ 7:09 pm
Which type of video files did you use when it appeared? mp4?
Posted Wed 11 Mar 09 @ 2:31 pm
thanks sischo..hi djcel..thanks
i normally use avi ,mpeg, and mkv..i do have some mp4 too.
last night i had a terrible night . had show logo 2 displaying a logo (ruff ryders r symbol)had a video playlist running and got a few song requests so i threw them in . as normal the soniq fx came in for the songs the video came in as normal.
i decide its time for me to start mixing and loaded a video onto the second deck i got the computer glitchy sound and couldnt get rid of it!
tried turnin off timecode ..safemode ..overclock..moved slider all way 2 the left ..ticking the ultra asio box on n off ..nothing.
i threw a cd in the deck and played a few tracks while i tried to troubleshoot then just loaded serato but i couldnt finish my video set cause ive been too busy to convert my vids over(not really sure which format will b best for both programs)
i need to get this solved b4 thursday when i go back there.what should i do
Posted Wed 11 Mar 09 @ 3:32 pm
Posted Wed 11 Mar 09 @ 3:52 pm
I noticed that some of my mkv videos cause problems. I quit using them and things seem to be better. It was like the computer couldn't handle it. It just bogged down. Video stopped but audio continued, etc.
Posted Wed 11 Mar 09 @ 5:55 pm
I thought to mkv too. Do you use "Video Decoder" with them?
Posted Wed 11 Mar 09 @ 6:05 pm
Yes I did.
Posted Wed 11 Mar 09 @ 6:11 pm
If you can identify one .mkv which freezes more the video engine than others, I'm interested to analyse the file.
(I can give you a FTP access to upload it)
Posted Wed 11 Mar 09 @ 6:16 pm
I'll see if I can find it. It doesn't happen with all mkv files. So far i've only had it happen on my club's computer. I haven't tried my laptop yet. If I have some time tomorrow I'll see what I can dig up.
Boogie, what about you? Do you have the problem when using mkv files?
Posted Wed 11 Mar 09 @ 8:55 pm
yup..i use video decoder for all video file types.
i will pay more attention next time i mix what type file it is...i notice that i mostly have problems when using asio or external soundcards with tccds
i did notice when the playlist was transitioning before the end it would b like a 2 or 3 sec pause or glitch in audio and video
Posted Thu 12 Mar 09 @ 12:45 am
hey Boogie,
Check the aspect ratio of the mkv files...see if the ones you are having trouble with are 1280 x 720. in VDJ browser right click on the file and go to "file infos" and it will tell you what the aspect ratio is.
Cel, I sent you a PM.
Posted Thu 12 Mar 09 @ 6:10 pm
well yesterday i jus plugged laptop directly to mixer with 1/8 to rca.internal mode. not i single problem the whole night.
i will go through the mkv files and see if i can find one to cause a problem
Posted Fri 13 Mar 09 @ 10:32 am
fridays gig..
setup with maya44usb with no timecode.. external mixer
in 20minutes recover smiley face .crash report:
Crash ID=70bde0c7 (date=903132334, version=5.2.1 Pro, build=521, thread=Video, dump=8b50048b, excode=c0000005 (0,4))
was using auto playlist with videos; played 2 mp3 songs computer crashed when i turned on show logo 2.
restarted vdj with recover.shut it back down then reopened it.
vdj ran fine except i had to turn off video transitions to none cuz when transitioning from one vid to the next the sound woud go computery for a bit then return to normal..but i ouldnt afford another crash so i switched it to none
Posted Sat 14 Mar 09 @ 4:05 pm
1) it's an external crash maybe because of the pluggin show logo.
2) how is your option in vdj : decode while hidden?
Posted Sun 15 Mar 09 @ 5:17 am
decode while hidden is not checked..
should i try using it?
Posted Sun 15 Mar 09 @ 10:06 am
yep, mine always is....
Posted Sun 15 Mar 09 @ 10:15 am
Yes, it will be better during video transition
Posted Sun 15 Mar 09 @ 12:54 pm
ok i will check it and try it out .thanks tayla /cel....
is there anything else i should try ?right now im open to all suggetions.lol..jus want to get this resolved or i might have to give up my tues /thursday video gig.hehe
Posted Sun 15 Mar 09 @ 1:37 pm
