Topic: Help!! I Recently Bought a Gemini Ps-626USB Mixer and can't configure it to work with Virtual Dj Internal Mixer.
I recently Bought this Mixer And want it to work Like The MIDI Controls But it won't. What Do I have To DO???? I really Don't Want To Buy Another Mixer Any Solutions Out there...
Posted Wed 04 Mar 09 @ 6:47 pm
You won't be able to. This mixer is NOT a MIDI mixer.
The USB cables are the inputs for the built- in soundcards. It'll sound nice but it will not support ASIO mode so, no timecoded either.
http://www.geminidj.com/ps626usb.html
Here's the Product page and you can download the manual there.
I could be wrong but i dont think this is a midi mixer so it wont work to control midi.
EDIT: ^^SNAP^^
Unless you're mixing video, you don't need the mixer to control virtual dj's internal mixer. See my video:
Okay, so I get that you don't need a midi controller. I use or have an Hercules deejay 4&6 but can't get it to recognize my timecodes with my numark USB mixer. How do I set that up inside VDJ?
The Numark USB mixers are NOT asio (audio stream in/out) compatible.
people if you don't have a usb or firewire connection coming off the miser IT WILL NOT WORK for time code or midi. research your equipment before you buy it cause its cheap or on sale.
