Hi Fellows and fellettes!
How do i correct the Problem in v5.2 where im trying to record my video mix?
In record menu Audio Record Works fine, but video record say" No Video codec error "
i have win xp with service pack 3 installed, direct x9c installed, and other v5 versions have worked Great with audio only.
also why in record config menu it says mp4, when on all windows systems mediaplayer has probloms with mp4s from fresh install? and codecs are a nightmare to find.
if vlc player was imbedded in windows there would be a lot less compatibility problems with windows and virtual dj, would you agree?
Can any one help please?
Posted Thu 26 Feb 09 @ 1:13 pm
ANYBODY there?
Posted Fri 27 Feb 09 @ 3:03 am
Hi rob,
I have never used the record video function, mainly as i am a mac user and it isnt an option in there.
BUT......I have just tested in on my Windows XP machine and it displays the same error.
I know this wont help you to fix it because i dont know what to suggest but atleast you know your not being ignored.
Posted Fri 27 Feb 09 @ 6:36 am
Thanks djtouchdan
there is someone there! haha
how do you record video mixes with mac djtouchdan?
As Was thinking of recording with second P.C laptop? can this be done ANYONE? and if yes, How plz
Posted Fri 27 Feb 09 @ 7:18 am
i dont record the video mixes. And in theory if i was id run it into a DVD recorder/HD Recorded - thus eliminating the problem the codecs etc. Prob not ideal but not something i'm worried about doing at the moment.
Posted Fri 27 Feb 09 @ 7:41 am
@rob.... well it's as i said earlier, dan is another one to favour the dvd way...
Posted Fri 27 Feb 09 @ 7:47 am
Look in my blogs under: recording a video performance.
Posted Fri 27 Feb 09 @ 8:18 am
yep i already gave him the two versions how to marcel earlier, but by pm, thanks..
Posted Fri 27 Feb 09 @ 8:37 am
you need to download
Xvid-1.1.3-27042008
then type xvid in record video config hit ok should be good to go
works for me
Mark
Xvid-1.1.3-27042008
works for me
Mark
Posted Fri 27 Feb 09 @ 12:19 pm
I was anxiously expecting the version 6 release to experience the video recording feature.
But the problems remains the same: video freezes and audio/video delays.
Yes, Im using the correct MPEG4 codec.
Any ideas to solve this issue?
I tested other capture softwares (as FRAPS) and works fine, without freezes and delays.
Posted Tue 02 Jun 09 @ 11:22 pm
Nvidia video card?
Posted Wed 03 Jun 09 @ 2:40 am
Yes, Nvidia GeForce GO 7600.
Im using the latest Nvidia drivers. Is there any setup to fix it?
Posted Wed 03 Jun 09 @ 8:16 am
I get this error on both my machines
Posted Wed 03 Jun 09 @ 9:27 am
I forgot to mention: playback is fine, no delays and freezes.
The question is only about the recording movie feature.
Posted Wed 03 Jun 09 @ 6:57 pm
