Forum: Old versions
Topic: Problems with vdj 5.2
DJ213Home userMember since 2009
it keeps showin on my laptop that it display resolution low and the skin i am useing is to high i never had this problem b4 on my old laptop or my new one i am tryin to install it on the only difference is the my new laptop has vista my old on has xp
i also bumped my display resolution on the new laptop to 1920x1200. if anyone can help me that would b great
Posted Sat 10 Jan 09 @ 11:12 am
Posted Fri 13 Feb 09 @ 12:46 am
Try opening VDJ then push the restore down square at the top right hand side of the screen then close VDJ and reopen, sometimes this can make a difference
Posted Fri 13 Feb 09 @ 7:57 am
