Forum: Old versions
Topic: My setup solution to VDJ 5.2.1, Maya44 USB & TCCD - Page: 1
Hey everybody,
After struggling for a few days, I finally got the Maya44 USB sound card to work with TCCD. I am posting all the settings for anyone that is running into trouble because it was a pain in the arse for me. I hope this helps. For my setup, I am using the Pioneer CDJ-1000 MK2 cd players but just about any cd player will do. I assume that you have wired up the Maya44 USB sound card and installed the Control Panel at this point. Here are my settings.
Maya Control Panel setup:
Monitor: Mute both In 1+2, In 3+4
Output: Max and unmuted
Input: Approx-85% otherwise the signal will be too strong when you do Auto-Config later on. Also unmuted.
Close
Audio Device setup on Mac:
Open Finder > Applications > Utilties > Audio MIDI Setup.app
Create Aggregate Device
Under "Properties For:" select Aggregate Device
Click "Configure Device"
Check both Maya44 USB
Done
Format: 44100.0 Hz
VDJ setup:
Inputs: Timecodes
Outputs: External Mixer
Sound card(s): 4-In/4-Out Card
Driver 1: Aggregate Device
Click Time Code Config
Select CD not Vinyl
Signal: VDJ Timecode (v4)
Insert Time Code CD and start playing. I am assuming that you have all this connected properly at this time. If not check the manual for the hookup.
Click Advance View >>>
Select Invert Stereo on left side only. For some reason if you don't it will play backwards. Weird!
Click on Auto-Config
You should see some sort of signal at this point. You're done!
Posted Mon 24 Nov 08 @ 3:51 pm
It's because you have your cables crossed on your left CD player.
But great information! Thank you...
VJ Productions... This is great news! Previously only a few interfaces worked with timecode. Have you done extensive testing with this setup? If so, please let us know what type of testing you did. Currently, I have to use a RMX for my setup with a perfectly good DJM-600 sitting in the garage. If this works for 4 or 5 hour gigs with no problems, please keep us posted. If it works, I'm sure some of us will be asking Santa for a Maya sound card.
I've used the Maya44 USB on a PC with VDJ previously and it worked fine. There were no hiccups on the PC setup but I'm new to Mac so it was a bit more challenging to me. I played around with new setup for about an hour and it works just like it did on a PC. Just remember not to turn on the tempo on the Pioneer. A side note...I forgot to mention to set the sound card latency to auto. Let me know if you need help with a similar setup. Have fun!
As for testing, I stress tested the VDJ key lock by setting the Pioneer pitch range to 100%. No hiccups, not even on videos. Make sure your Mac can handle it. I'm using a Macbook Pro 2.6 GHz, 2g ram. Btw, the Maya44 USB is discontinued but I'm sure you can find one used.
No it was re-issued and is readily available again.
Great feedback VJ! I believe I'll be looking for a Maya soon so I can knock the dust off the 600.
Works the same on mac for full size turntables, except obviously select "Vinyl" on the "Timecode Config" - Mine works fine with "VDJ Timecode (V5)" for me.
Just thought I would confirm this. As I have this fully working myself.
Glad it work too for you;)
And pls register ur serial in ur modify ur profile. Thanks.
Regards.
Mac tech support forum moderator.
I did everything in this post, but still no signal..
I've got this cd-player: Dap Audio 900-D and a macbook pro
Anyone knows what the problem can be?
Does VDJ support timecode for mac with cd's? Or only vinyl?
Have u create the maya in the audio midi set up as aggregate device?
I found it! It was the aggregate device ;)
Thanks!
Cool glad u found it;) Now enjoy it..hehe
Regards;)
anyone knows if the stanton final scratch open will work with those settings????i have very big problem....
For timecodes purpose i don't think it will at the moment but for normal use it is possible. Just create the aggregate devices for it in audio midi setup:)
Regards;)
Hi
My signal drops after 1-5 min. And my englis is bad. But i understand what you write :)
i have a hercules rmx console and im just wonderin how to prgram the soundeffect buttons?? can anyone help me?
Hey everybody,
Close
Done
Format: 44100.0 Hz
VDJ setup:
Inputs: Timecodes
Select CD not Vinyl
Are you running Leopard?? How did you get the even get the control panel?? Mine won't install off the cd it came with.
I have U46DJ sound card running on Mac OSX 10.5.6 with TCCD. I don\\\'t have aggregate device with going to midi setup. I can\\\'t get VDJ to work with the sound card. The TCCD don\\\'t come thru. Any help?
74%
