Loving it! Playing like a dream at the moment!!
Posted Sat 17 May 14 @ 9:31 am
Just as soon as I can have it running at my default screen resolution of 1920x1080 it is soooooooooooo going to stay running on my 50" plasma lol.
Posted Sat 17 May 14 @ 10:50 am
Me likey. :) Now just need a more beefy laptop.
Posted Sat 17 May 14 @ 11:05 am
I don't know what happened but I swear I didn't have freezing issues the past builds but now all of the sudden when loading any video to the opposite deck both the main output and the skin freezes til the waveform is finished loading.. I don't know what is going on. Anyone else notice anything similar?? Running 1765. This is with Milkdrop enabled, If I use sonique all runs flawless. Milkdrop works perfect in 7.4.1 so I don't know if it is just a setting in 8 or what.
Posted Sat 17 May 14 @ 2:09 pm
I'll have to have a look at it...
Posted Sat 17 May 14 @ 5:54 pm
Whats in store for the Mac side??
Posted Sat 17 May 14 @ 6:45 pm
Two things being worked on for the Mac side:
Quartz Composition support
projectM (which is compatible with Milkdrop presets)
Posted Sat 17 May 14 @ 6:51 pm
Nice!! Well Ill keep doing what Ive been doing then, can't wait for QC support!!
Posted Sat 17 May 14 @ 6:53 pm
Hopefully I'll get Syphon Client up and running too so you'll be able to pump from Resolume into VDJ, rather than just the other way around.
Huey's been testing a PC equivalent to Syphon for me too with Resolume ;)
Posted Sat 17 May 14 @ 6:56 pm
And it is badass!! I was and still kinda am as how well its working!! Almost to the point of switching back to a PC from a Mac and thats no BS.......
Posted Sat 17 May 14 @ 7:56 pm
For now my workaround is to have Sonique on audio only then simply turn on Milkdrop right before I fade to that deck. Workin good like that tonight.
Posted Sat 17 May 14 @ 10:45 pm
PLEASE! I need this to run @ 1920x1080 60FPS! :) It's OK my setup can handle it ;)
Posted Mon 19 May 14 @ 7:52 am
Haui70 wrote :
I'm a poor Mac user and hope see it soon on this side too ;-)
I hope it, too.
Posted Mon 19 May 14 @ 8:12 am
What happens when you try to run it at 1920x1080 then?
Posted Mon 19 May 14 @ 9:22 am
You have an orgasm and your head explodes. No really it looks AM-A-ZING!
Oh and vsync on please.
Posted Mon 19 May 14 @ 3:13 pm
I think you misunderstand me.
What happens if you run your VDJ output at the required resolution, with the plugin enabled and high quality mode (ie 2k texture sizes) enabled?
Control of FPS and vsync are outside a plugins remit; they are controlled by the VDJ video engine obviously.
Posted Mon 19 May 14 @ 4:21 pm
LOL !!!!! +10000
Posted Mon 19 May 14 @ 4:37 pm
Scott have you found anything that would be causing the ext monitor to freeze on track load?? Like I said as a workaround I am simply using the effect instead of using it for all my mp3s.
Posted Mon 19 May 14 @ 4:42 pm
How do we get sonique to work? It does not even show up.
Posted Mon 19 May 14 @ 5:34 pm
Sonique files are now natively supported.
If you place your soniques in this folder:
MyDocument/VirtualDJ/Plugins/Visualisations
The you should see them in the effects lists.
Posted Mon 19 May 14 @ 5:39 pm
