i need to know is there a way to use live video and put it thru vdjs video output
thanks
thanks
Posted Thu 02 Jun 11 @ 12:38 pm
i bought a microsoft HD webcam,
If i connect it to my pc en go to the video effects page, turn on Camera ;) i get a live feed trough vdj.
so the answer is YES u can :)
Posted Thu 02 Jun 11 @ 12:44 pm
thanks!!!
now my other question is can I re size or mask the video feed? Im setting up a new karaoke system at a club and they want the karaoke videos and live video of the singer in the same video output... is this possible?
Posted Thu 02 Jun 11 @ 12:49 pm
Posted Thu 02 Jun 11 @ 1:17 pm
ok i found the camera effect. i turn it on and i get a black screen tho. My isight web cam on my macbook pro works fine. what am i doing wrong?
Posted Thu 02 Jun 11 @ 1:40 pm
Did you config the source?
Posted Thu 02 Jun 11 @ 1:43 pm
fixed it... something else was using the web cam... so far it looks like im gonna have to use 2 screens.... :( some one should make a plugin that lets both the karaoke and the live video play together in the vdj output window
Posted Thu 02 Jun 11 @ 1:48 pm
SOLVED!!! firetext plugin does exactly what i was talking about... now how do i turn the firetext logo off ?!?!? lol
Posted Thu 02 Jun 11 @ 1:56 pm
answered that for you in your other post. Firetext allows PIP (picture in picture) show your audience on screen as well as other video outputs, great for karaoke singers, audience in venue while playing music videos, speakers at conference, even sports events while playing vids.
Posted Thu 02 Jun 11 @ 5:54 pm
ok this is gonna be a stupid question but iv been looking fo ra live cam plugin for ages for the mac version so where did you find it please as it didnt come with virtual DJ 7 for teh mac only with the pc version
Thanks
Andi
Thanks
Andi
Posted Wed 24 Aug 11 @ 6:23 pm
Need Help ! I am trying to run a Live Video Feed from a Sony DVCAM through Virtual's Camera Effect. The problem I am facing is, The Digital Out Put on the camera is Mini DV and the laptop I am using has no firewire connections. I have 2 unused USB ports open and a eSATA port available. Any one have any ideas how i can turn a firewire into a usb or something compatiable.
Posted Thu 08 Sep 11 @ 2:50 pm
Mini DV to USB can be found http://www.amazon.com/s/?ie=UTF8&keywords=usb+2+mini+cable&tag=googhydr-20&index=electronics&hvadid=3451388339&ref=pd_sl_87t3yu0xy3_b" rel="nofollow" target="_blank">here.
Posted Thu 08 Sep 11 @ 3:05 pm
