I've noticed you're on MAC, i'm using windows so you can't count on me...
Posted Thu 19 Mar 15 @ 10:20 am
It is a Mac bug maybe .... I have a windows laptop ... I'll give it a try tonight
Posted Thu 19 Mar 15 @ 10:35 am
I just tried under windows and it's exactly the same bug under windows .......... frustrating
Posted Thu 19 Mar 15 @ 6:18 pm
think u could make a short video so we can see whats happening
Posted Thu 19 Mar 15 @ 8:08 pm
I've posted a short video on youtube , please watch and if you can help i'll be very grateful
PS : My config is Macbook Pro 15 early 2011 i7 2,2 ghz 16 GB Ram
https://www.youtube.com/watch?v=P7dwlYTSZUA&feature=youtu.be
Thank you in advance .........
Posted Fri 20 Mar 15 @ 4:57 am
very odd indeed ... is it possible one of the buttons on the controller are stuck in the down position?
ok maybe not after reading that it works normal if u activate another way
sorry i have no idea
Posted Fri 20 Mar 15 @ 5:31 am
yes indeed , I have thought exactly the same thing about the button but when I switch the skin to VDJ 8 default skin it stops and acts normal and in Serato it acts normal as well ....
So I thought that it's something related to djdad custom skins .... but then why only me and not other users .......... I'm lost ..........
Posted Fri 20 Mar 15 @ 5:38 am
and once again if there is a stuck button in the controller itself why it does still work flawless using the same djdad pad skin and having the slicer FX on in the first slot or just when I pin the Slicer parameters to the background ........ quite strange .......... and I have reset the slicer parameters several times by deleting the native_slicer_ini in plugins 64 .
Posted Fri 20 Mar 15 @ 6:00 am
anyway thank you wickedmix for your effort , appreciate your effort to help ....... ;-))))
Posted Fri 20 Mar 15 @ 6:01 am
It also can be a problem in the firmware try to update or reinstall the latest firmware for ddj-sx from Pioneer
Posted Fri 20 Mar 15 @ 6:32 am
I already did twice but I will do it again ... and I have reset to serato mode as well .....
By the way does anybody know how to get slicer mode work like serato ..... to loop and slice ???
Posted Fri 20 Mar 15 @ 6:43 am
Long press the slicer mode button, I think...
Posted Fri 20 Mar 15 @ 6:55 am
without shift ??? native mapping ???
Posted Fri 20 Mar 15 @ 7:04 am
I think that is a firmware function, not related to mapping. Just like toggling the sample mode to velocity sample mode by longpressing the sample mode button.
Posted Fri 20 Mar 15 @ 7:37 am
so on vdj 8 ddj-sx all set to native if I long press Slicer mode i'll get the same function as Serato ???
Posted Fri 20 Mar 15 @ 8:13 am
I have again reset controller to factory settings re-upgraded again ti 1.07 , reset to serato mode , but ALWAYS the same bug :-(((((((((((
It's painfullllllll
It's painfullllllll
Posted Sat 21 Mar 15 @ 5:24 am
Issue is reported . Be patient
Posted Sat 21 Mar 15 @ 7:17 am
Ok , djdad , I'm waiting .... Just giving an update .... Thank u again for your effort
Posted Sat 21 Mar 15 @ 7:49 am
I have the same problem using the parameter on the slicer and on the loops/roll as well.
Posted Tue 24 Mar 15 @ 11:15 am
Bug found from Dev Team and will be fixed in next Beta build
Posted Tue 24 Mar 15 @ 4:31 pm
