djmicron wrote :
my feedback at the moment is:
vdj timecode works perfect in smart, relative and absolute mode
serato timecode only works in relative mode or it will generate random skips.
Inside vdj 7 timecode settings, there is a "silence" parameter to avoid unwanted skips when the platter is running and the hand is on the vinyl, this is possibly a task that on vdj 8 is done automatically and still to be fine tuned.
Vdj timecodes - you are talking about CD's right... Got to be..
I don't think they even sell virtual dj records in stores anymore.
Posted Fri 01 Aug 14 @ 12:33 pm
I have vdj time code vinyl...andsince v8 these are what have performed better for me . and actually for 299. maybe consider them part of the package.. I rather spin time code matching software. and since I'm talking, 99 decks is wasted technology how about 4 decks and use the some of that power from the other 95 decks and implement 2 optional post fader effects
Posted Fri 01 Aug 14 @ 1:21 pm
hi, i'm talking about vinyl timecode, i don't know if they are still for sale, i have some i bought some years ago.
The serato timecode cd is fine if used over digital output where there isn't background noise, so i'm almost sure that the "silence parameter" available on vdj 7 and missing on vdj 8 can fix the timecode issues.
beatbreaker1 wrote :
Or just drop it all together..........
if they drop timecode i want my money back and you can lock my account cause i have no use for software with no timecode.
Posted Fri 01 Aug 14 @ 4:40 pm
I been working out these vdj vinyl and i have no more problems no drift, skipping, gonna do some 1 to 2 mixing and see if the speeding up problem is still there....but im done im just going to use vdj timecode. If im not mistaken they are still listed for sale in the merchandise section. Plus i starting to enjoy having the vdj label on my turntables. Never understood the need to use serato vinyl or timecode when you have your own, time to stomp with the big dogs, right now we on the porch looking
off.
off.
Posted Fri 01 Aug 14 @ 4:45 pm
off.
off.
Vdj timecode vinyl work exactly the same as serato on virtual Dj 8 I am going to do a video so u can see .But I agree with they should just forcus on vdj vinyl to get it right .but I been using vdj vinyl and in the beginning of the track it still jumps in to soon like serato timecode I don't have jumping so much on both timecode vinyl .and it still speed up on virtual Dj timecode vinyl to.trying to get the time to do a video.
Posted Fri 01 Aug 14 @ 5:28 pm
im not having the jumping i the beginning i used to but what i did to fix it might not apply to others
Posted Fri 01 Aug 14 @ 6:50 pm
here i just did 2 video's so u can see look at the whole video everybody in the timecode forum and the dev team.this is crazy i have to keep doing video's and still get no help from the dev team.To Djratedxxx919 i curse in the video but its not towards u.it for the software get me piss off u will see in the video's
https://www.youtube.com/watch?v=_WzMBZSSHGM&feature=youtu.be
https://www.youtube.com/watch?v=PII62S34aUc
Posted Fri 01 Aug 14 @ 8:05 pm
hi,
my vdj timecode is a different version, its label is a big straight virtualdj logo in white and black on a red background and i bought it back in 2007, i don't know if the timecode is the same as yours
My serato vinyl is cv02.5.
I tried setting up serato timecode while using the virtualdj one and it apparently works, but pitch is wrong and the timecode analysis shows "no position", then i tried setting up virtualdj timecode while using serato and similar result as before, apparently it works, but wrong pitch and no position detected.
If you play the turntable while the timecode window is open, you should see that no position is detected when using the wrong timecode brand.
I can't try serato software, it surely handles the timecode in a different way, i'd try absolute mode to see if the position is right when virtualdj timecode is used under serato, but on vdj 8 it's enough to invert the L/R channels and it doesn't work and also inverting one channel phase it will play backwards.
Posted Fri 01 Aug 14 @ 9:26 pm
Im uploading a video now doing the same thing as you are but im not getting these problems anymore...how did you set lead to 500,000...is it like 0.5000000 or 5.000000
oh yea my lead-in is 10.000000
Posted Fri 01 Aug 14 @ 9:38 pm
