Topic: DJConsole MK2/MP3 - Vista update - Page: 8
here they are
GATEWAY LAPTOP MT6451 NOTEBOOK
OS: MICROSOFT WINDOWS VISTA HOME PREMIUM
PROCESSOR: AMD TURION 64X2 MOBILE TECHNOLOGY TL-50
256 KB X 2 L2CACHE, 1.6 GHZ
MEMORY: 1024MB DDR2 DUAL CHANNEL
VIDEO: ATI RADEON XPRESS 1150M GRAPHICS WITH UP TO 256MB OF HYPER MEMORY
HARD DRIVE: 120 GB PATA, 420O
OPTICAL DRIVE: MULTIFORMAT DOUBLE LAYER DVD +-RW
NETWORK: 802.11G WIRELESS LAN
10/100MBPS ETHERNET LAN
PORTS/CONNECTORS: 4 USB, 1 IEEE 1394, 1 S-VIDEO, 1 HEADPHONE, 1 MIC, 1 AC ADAPTER \
It's there anything else i need to do with this situation. any other software download?
@millie
Can you try your console on some other PC with Vista? Just to make shure it is not problem with your laptop. Specs are good, shouldn't be any problem. Also, try to add power adapter to your console and see what happens.
thanks
thanks
fewrtgwegwerg
did just tried on another vista desktop and laptop. same problems. tested on xp, perfect there. going to try the power adapter, but i dont think thats the problem, i'm not the only person going thru this problem, Hercules says is virtual dj, that their update for the console is not working 100%. My friend has virtual dj 4, same problems on vista as mines. Please help. Thank You.
Oh by the way, can someone tell me what will be the best power supply for the console?
volts?
thank you
You have described that in the manual of the console, mine isn't here, but I think it is 7-9 volts 800mA.
would using an ac adapter fix anything?
there got to be more than that.
Nope, but it won't hurt to try ;)
I didn't had the time to try MK2 with Vista, is Simon helped you? Sorry to hear you are still having problems.
Im going crazy, have a gig this saturday and dont know what to do. called hercules, did all the testing on 3 different vista comp. 1 desktop and 2 laptops, same problem, tried on xp, perfect. It is virtual dj and vista.
You mean VDJ Console version, the Pro should work fine. Hm. I will try to install tomorrow Vista and will download Console version and try it out. Can you use XP in any way in saturday? It will give us more time to resolve this one?
nahh, not possible. been calling everyone. help please
out of all those computers... you can't switch one of them to XP for you gigs until Vista is working for you?
Suppose the computer goes down for whatever reason, do you have a backup plan... if so, use the back up.
no more xp pc on stores, im going with a mac, even that i hate the friking thing with a passion. thanks
dell has started stocking xp pcs ;)
due to popular demand
mac is cool 2 i use a mac now
that doesnt help right now. lol. i sended you the specs on my laptop, did you find out anything?
please post them here your emails bounced by thel looks of things.
here they are
anyone?
no one?
seems ok ,
have you checked for any device conflicts see my blog for info on this.
81%
