i did check. nothing there....
Posted Wed 25 Apr 07 @ 6:10 pm
@millie
Here is what you can try:
disable everything you don't need, like wireless, lan etc. Try do to it from bios, if there is a option. You have some sort of drivers/hardware conflict and it is not easy to find it, belive me. If something improves, enable one by one part to see which one is causing the problem. Did ya tried a clean install?
I didn't had the time to test Vista with Home and Mk2 but will at monday, will have some spare time ;)
Tell us what you did and we will see what you should do next.
Posted Sat 28 Apr 07 @ 4:04 pm
No one else, no new updates on the situation?
Please help...
Please help...
Posted Wed 09 May 07 @ 5:49 pm
Well, last night I finally got a chance to put MK2 on Vista... I followed sky's steps to a "T", well I think I did. Digging in my configs is not my forte. But the system works very well. The music loads in 2-3 seconds, video loads in about 3-6 seconds... The affects and transitions run very smoothly even with back to back video and affects and I'm not using a high powered video card.
Posted Mon 14 May 07 @ 4:31 pm
well, i hace tried everything, including a power supply. still the same slow responce on the buttons and the delay on the comunication between the mk2 and software. does anyone has any good news?
Posted Thu 24 May 07 @ 3:06 pm
ok
Posted Fri 25 May 07 @ 5:50 pm
Now I've read every Thread concerning Vista-Problems and I tried all, nothing has changed.
Its terrible, I WANT TO USE MY MK2-CONSOLE WITH WIN. VISTA (Home Premium) !!!
Posted Tue 05 Jun 07 @ 11:08 am
I have to say mine works like a dream.
What is the PC you have:
Make:
Model:
RAM:
What else do you have plugged into USB ports
Make:
Model:
RAM:
Posted Tue 05 Jun 07 @ 2:17 pm
Thanks for your answer :)
I bought a new laptop 2 weeks ago from SAMSUNG (germany):
-Windows Vista Home Premium
-Intel Core Duo 2x 1,73Ghz, 1mb L2 cache, 533 MHz FSB
-Ati Radeon Xpress 1250 with 128MB
-2GB DDR2Ram
-160GB HDD
...and NOTHING plugged on USB (just the mouse)
I already have installed the updates of VirtualDJ and Hercules but it appears the error
"Fehler im Directx Soundtreiber" => Error in Directx Sounddriver
I swear I read all threads concerning this error with vista but there was no final solution :(
-2GB DDR2Ram
-160GB HDD
Posted Tue 05 Jun 07 @ 10:00 pm
the solution is the following
for those who missed it higher in the thread
1. uninstall console and vdj
2. reboot
3. go to control pannel then user acounts , find your acount and set it to administrator Group
4. reboot
5. reinstall
horray its working.
2. reboot
4. reboot
5. reinstall
horray its working.
Posted Tue 05 Jun 07 @ 10:25 pm
Okay. Have you checked Direct X using the tool.
Goto Help and Support and search for Direct X.
Look for the option "Run Direct X Diagnostic Tool"
Run the tool and see if it shows any errors.
NEXT if that does not help.
Use "System Restore" to return your system to a state when Direct X was not a problem.
Make sure you have downloaded all the windows updates.
Install the Hercules Mk2 Software
Install the updated XP driver
Plug the Hercules in
Start Virtual DJ
Update as required
You should be good to go
When I first installed the Herc I never seen the icon down by the clock (bottom right) I had to browse program files to find the file and run it. Once run it is always there on start up.
Let me know how you get on. I realise this is pretty frustrating as you have the required kit to have a good setup.
make sure it all works with the supplied version of VDJ. I never bothered with latset version as it never worked on XP correctly for me never mind Vista.
And as Sky has said above you will need to be Administrator
Start Virtual DJ
Update as required
Posted Tue 05 Jun 07 @ 10:27 pm
Thank you very much for your postings!!!
well my useraccount IS an administrator one!!
Now i will try to run this directx diagnostic tool,
i hope its gona work after that =)
Later i'll report if it was successfully^^
Posted Wed 06 Jun 07 @ 12:33 am
I cant believe it.... i just deinstalled all
entries which include the name "hercules"
and "virtualdj", reboot my computer, first
install the new hercules driver and after
that virtual dj....IT WOOOORRKKSSSS!!!!
Thank you Thank you Thank you Thank you!!!!!!
You can't believe how many hours i already
invest in this problem!!!
Posted Wed 06 Jun 07 @ 1:38 am
good to hear :)
Posted Wed 06 Jun 07 @ 2:01 am
No problem mate. Go enjoy your new toy
Posted Wed 06 Jun 07 @ 9:48 am
Hy, i am a new user of this program(VirtualDJ) and is ok and lot of fuuuuunnn!!
I like it very much and i have just good words about him i hope in the future to put some musik for my friends with this program...
i wish the best to everyone......
subscribe
ME, MY SELF AND I !!!!
subscribe
Posted Wed 27 Jun 07 @ 2:00 am
I'm upgrading to a new laptop--and unfortunately---every laptop that has any kind of nuts in the way of RAM and power...is now running VISTA. Can anyone send me the EXACT proceedure and what (and how) to download into a virgin computer? I am a VDJ PRO user with the PIONEER-1000 skin. Gracias!
DJ SNOW
DJ SNOW
Posted Thu 28 Jun 07 @ 9:49 pm
Nice Man looking good
Posted Fri 29 Jun 07 @ 7:27 pm
Hello I would like to know is this who would have quelq' one which would be able to do one mixes with put 3 or 4 songs to add worse special effects in mixes
Posted Sat 14 Jul 07 @ 6:07 pm
trying to install VD 3-working on VISTA BUSINESS i get the erorr:
''String IDS_Target Req_DESC_OS was not found in string table''
plz....someone...help...
Posted Tue 17 Jul 07 @ 9:59 pm
