Hello all,
I'm having a little problem. My record case freezes occasionally. It doesn't happen every time I use VDJ but still it is rather annoying. The music continues playing but I'm not able to do anything else. Has anybody got any ideas???
Pentium 4 3GHZ
1GB RAM
250 GB hard drive
Rack mount
Thanks
TommyB
Pentium 4 3GHZ
1GB RAM
250 GB hard drive
Rack mount
Thanks
TommyB
Posted Fri 15 Dec 06 @ 12:44 pm
tryed a defrag?
tryed a differnt skin?
try loweing your proformance tab aslo
Posted Fri 15 Dec 06 @ 12:50 pm
Thanks Skyfxl
I am just using the normal full vid skin, will change to just full audio.
What do you mean by lowering performance tab??
Thanks
TommyB
Thanks
TommyB
Posted Fri 15 Dec 06 @ 12:59 pm
lower your proformance tab :-)
Posted Fri 15 Dec 06 @ 1:08 pm
I'll give it a go.
I'll give it a go.
Posted Fri 15 Dec 06 @ 2:49 pm
good luck :-)
Posted Fri 15 Dec 06 @ 2:51 pm
98thbear wrote :
Hello all,
Pentium 4 3GHZ
1GB RAM
250 GB hard drive
Rack mount
Thanks
TommyB
Pentium 4 3GHZ
1GB RAM
250 GB hard drive
Rack mount
Thanks
TommyB
I've posted this problem a few times in the past few weeks already. Working with virtual folders causes the program to freeze. Well it doesn't freeze exactly but the display stops responding and you have to restart the program in order to recover.
Posted Sat 16 Dec 06 @ 7:02 pm
skyfxl wrote :
tryed a defrag?
skyfxl, i really don't see what the performance setting could possibly have to do with this. this problem occurs when nothing is even playing. when all i am doing is creating virtual folders and adding files to the folders, no music playing at all, and the display locks up, what does that have to do with performance settings?
Posted Sat 16 Dec 06 @ 7:04 pm
basicaly
i belive that the proformance level is to high
and the cpu cannot keep up
so therefore lags occured
Posted Sat 16 Dec 06 @ 7:37 pm
Just wanted to weigh in and say I have had the same problem...
I now largely use iTunes as my recordcase and it works well, though I wish I didn't have to screw around w/ another app being open.
Adrian
Adrian
Posted Sat 16 Dec 06 @ 10:45 pm
skyfxl wrote :
basicaly
but if NO MUSIC IS PLAYING, cpu use is very low. performance setting should not matter. dragging files to virtual folders should not consume too much cpu
Posted Sat 16 Dec 06 @ 11:06 pm
true
will investiagte :)
will investiagte :)
Posted Sun 17 Dec 06 @ 12:37 am
mine does that the first time I recurse, or the first time I open my master music database.... it's for like 30 seconds... makes your butthole pucker, but I know it's coming back, it just needs a second to sort the whole 600 gigs of info....
My machine is brandy new, smokin' fast and lightning quick, but it still hangs up for a minute when doing the initial opening....
-Steve
-Steve
Posted Sun 17 Dec 06 @ 3:03 am
What do you call "record case" more precisely ?
* When you are searching in a sub-folder of your hard drive?
* Local Database ?
* Global Databse ?
* Favorite Folder with sub-folder?
* Virtual Folder ?
* Suggestion Box ?
* Local Database ?
* Global Databse ?
* Virtual Folder ?
* Suggestion Box ?
Posted Sun 17 Dec 06 @ 1:29 pm
* Local Database ?
* Global Databse ?
* Virtual Folder ?
* Suggestion Box ?
* Local Database ?
* Global Databse ?
* Virtual Folder ?
* Suggestion Box ?
NOW thats what i was thinking.. know the source then solve problem(if the answer to this is a virtual folder ..its an issue being solve in update).:D
Posted Sun 17 Dec 06 @ 2:01 pm
* Local Database ?
* Global Databse ?
* Virtual Folder ?
* Suggestion Box ?
* Local Database ?
* Global Databse ?
* Virtual Folder ?
* Suggestion Box ?
Local Database - NO
Global Database - NO
Favorite Folder - NO
Virtual Folder - YES
Suggestion Box - NO
Working with virtual folders (even with no music playing) causes the display to freeze, requiring a restart.
Posted Sun 17 Dec 06 @ 6:45 pm
It happened again last night!
Was playing for a good 3 or four hours with no probs. Scrolling through my tunes and then it all just froze up although the music comtinued to play.
Anybody got any ideas??
Tommy
Tommy
Posted Sun 14 Jan 07 @ 3:56 pm
Just posting to get this back on the front page and to see if anyone has any ideas
Tommy :)
Tommy :)
Posted Mon 15 Jan 07 @ 10:07 pm
Tommy
Tommy
Computer Over hearting
Posted Mon 15 Jan 07 @ 10:14 pm
I did think that although I have a sever case with about 8 fans in it! :)
Posted Mon 15 Jan 07 @ 10:18 pm
