Hello all,
I've already raised the issue a few months ago here in the forum, unfortunately without success. Now I wanted to tackle it again because I still can't upload podcasts.
I can start an "audio" broadcast without problems - firewall is open and everything works. But if I start only a "Podcast" broadcast - nothing happens. no upload after stopping the podcast.
I guess I'm doing something wrong, the instructions don't really help, so please explain to me exactly, ideally step by step, what I have to do from the start, e.g.
1. start Virtual DJ
2. go to settings -> broadcast -> podcast -> start broadcast
3. start mix
4. finish mix
5. go to settings -> Broadcast -> Podcast -> Stop Broadcast
6. etc.
Those would be the logical steps in my eyes, but nothing happens there for me. I have also started the Audio -> Start Broadcast before the Podcast -> Start Broadcast and then stopped it at the end in different orders, but still absolutely nothing happens, also no error is visible.
What am I doing wrong?
1. start Virtual DJ
3. start mix
4. finish mix
6. etc.
Posted Tue 05 Oct 21 @ 6:00 am
When you stop podcast, what message do you get in BROADCAST tab of VirtualDJ Settings ?
"Do you see podcast upload complete" or "still uploading" ?
Posted Tue 05 Oct 21 @ 12:58 pm
There is no message - nothing appears
Posted Tue 05 Oct 21 @ 1:25 pm
Not even before u stop ? Like this...
![](/img/344972/68223/Image 11.png)
Posted Tue 05 Oct 21 @ 2:16 pm
No, I never saw the status uploading. also the time is always at 0 seconds, nothing changes.
Is my above mentioned step by step order correct?
Posted Tue 05 Oct 21 @ 3:17 pm
looks right, question what's your HW?
Posted Tue 05 Oct 21 @ 3:24 pm
I tried different. MacBook Pro (2020), Windows 10 PCs etc.
But if I do everything right, why is the time not running?
Posted Tue 05 Oct 21 @ 3:58 pm
no controller?
Posted Tue 05 Oct 21 @ 4:02 pm
Ahh, you mean my controller. I have a Hercules Universal DJ.
It´s only working when the controller is connected?
Posted Tue 05 Oct 21 @ 4:06 pm
no, just checking if you had a HW [perdeck] device waiting for sound [turns out that doesn't matter for podcast]
Best I can think of is some sort of mac security issue, but I don't know macs.
Posted Tue 05 Oct 21 @ 4:17 pm
My main pc is a Windows 10 pc, so I don´t think that it´s a security issue
Posted Tue 05 Oct 21 @ 4:26 pm
Is there anything else about the configuration that I need to consider?
And again the question why the time is not running?
Posted Tue 05 Oct 21 @ 4:59 pm
Does normal recording work?
If the time doesn't increment that usually means there is a problem with the audio configuration. (perhaps non-functional record entry)
Posted Tue 05 Oct 21 @ 5:03 pm
If you mean file recording, yes, that works.
Audio config? That´s my config
![](/img/344983/13816/Unbenannt.jpg)
Posted Tue 05 Oct 21 @ 5:07 pm
No other ideas?
What I can say is that when I start a podcast, I see "Initialize...." for a millisecond, but after that, as I said, absolutely nothing happens.
Posted Wed 06 Oct 21 @ 6:24 am
But you do see 'Total Time:' ? but nothing underneath?
Posted Wed 06 Oct 21 @ 6:26 am
I see Total Time - always 0 seconds - time is not running
Posted Wed 06 Oct 21 @ 6:37 am
I only see this - the whole time - nothing changes, even when I stop the Podcast broadcast
![](/img/345011/16382/Unbenannt.jpg)
Posted Wed 06 Oct 21 @ 6:41 am
Again my question. It´s enough to select Podcast and then to click on Start Broadcast - no more steps necessary?
Posted Wed 06 Oct 21 @ 1:18 pm
No one can help?
Posted Thu 07 Oct 21 @ 4:43 pm
