Forum: VirtualDJ 8.2 Technical Support
Use this forum to report any bug, questions or comment related to the latest version of VirtualDJ 8.2.
Forum Guidelines
(NOTE: VirtualDJ 8.2 is continuously updated, so many older topic on this forum are most probably already fixed in the current build)
Topic: Pioneer DDJ-SR2 Compatibility for VDJ - Page: 1
Hello fam,
Does anyone have an idea of how long it usually takes for VDJ to include new controllers in the updates? I am looking at the Pioneer DDJ-SR2 and it is not compatible as of yet. It comes with Serato but I'd prefer to stay with VDJ as my choice of program.
Posted Thu 19 Oct 17 @ 1:58 am
For "a new controller" I would say usually a few weeks
The issue is that this is not just a controller - It's a Pioneer controller
Pioneer normally tries to block people from using any other software than the one that comes with the controller
So a new controller basically has to be reversed engineered to make it fully work with VDJ, which is time consuming work
For the xdj-rx it took about a year
So getting new Pioneer controllers to work is a bit like fighting IS in Syria
You have a feeling that the bad guys at Pioneer will loose in the end, and that the controller will be supported in VDJ - but it takes time
Posted Thu 19 Oct 17 @ 5:29 am
938MyDJPRO InfinityMember since 2007
Do you already have (or ordered) the unit?
You might want to check the Reloop Touch Control... Specifically made for VDJ.
Posted Fri 20 Oct 17 @ 11:22 pm
Thanks for the information on how long it could take for the update. There are a few features on the SR2 that I want specifically but I might need to go with the SR. I haven't bought it yet but it sure looks good in Guitar Center LOL.
Posted Sun 22 Oct 17 @ 5:50 am
Today I went to my favorite toy store (Guitar Center) to play around with the controllers. The DDJ-SR was on display but not working. I asked a salesperson to fix it but he couldn't so I asked questions about the controller. Above our head was the DDJ-SR2 so he got on the ladder to get it down. He said they were out of the DDJ-SR but the SR2 is the upgrade at the same cost. Now you know I've been looking at this every day online and the SRP is $699. Once he quoted me at $599 I asked him if he was sure. He said yes and off to the register we went. It rung up at $699 and he had a deer in the headlight look on his face. He called the manager and they adjusted the price to $599. I couldn't have gotten a better deal even on Black Friday! I will have to use Serato until it is compatible but it's worth the wait.
Posted Sat 28 Oct 17 @ 10:33 pm
Stay away from these i had the rmx 1 worked fine till i upgraded my account 6 years ago all ive had is problems when i try to do a remix. and know i bought the pioneer 350 and they worked biut instead i tried them on virtual dj and the same. synchs, beat lock BPM disingages when cpomes to end of track just as your starting the remix. So i sent them message this time tell them the company is bollocks since they took the two scammers on that where ruthless to take the company out. Now their ruthless at VDJ leave bad practise everywhere insted of putting it right. Ok so they took all my spare time for years. and ive just spent another 6 hours trying to sort out the problems which i did. and actually got it to work. So i wrote a scathing letter about there practice. It took about 2 hours to put it together and draft. and i just gone on the 350 with the software and nothing works at all now maybe coisidence. But those two porn loving stay up all night fat get offf on victimising companies or people. Now its my turn to tell your new customers not buy and take your company out. Ni hacking needed just word of mouth .
Edited for bad language. Please refrain from using bad language on this forum, as per our forum rules, thank you
Posted Sun 29 Oct 17 @ 1:43 am
I have no ide what you are talking about?
Are you mad at Pioneer?
Are you mad at Hercules (The RMX1 sounds like an old Hercules controller)?
Are you mad at Native Instruments (you mention NI)
Are you mad at Atomix?
Do you own a Pioneer DDJ-SR2 (like this post is about)?
What happened 6 years ago?
Where do the CDJs come in?
Your rant is very confusing
Posted Sun 29 Oct 17 @ 9:08 am
FYI, Official Support for Pioneer DDJ-SR2 will be provided in next Early Access Build
Posted Sun 29 Oct 17 @ 11:23 pm
Great News to see support for DDJ-SR2 in the early access build. That means i am now going to purchase the full version and upgrade from the LE license that came with my old numark mixtrack 3. Before i make the purchase i am just curious to know if the early access build means that i will be able to use my DDJ-SR 2 fully with virtual dj without any problems?
Posted Mon 30 Oct 17 @ 4:12 pm
Posted Mon 30 Oct 17 @ 4:18 pm
Great to hear this and thanx for your help djdad.From what you said,does this mean that the controller will be functional in short bursts of 10 minutes each whilst on vdj or it will be available full time for 30 days?
Posted Mon 30 Oct 17 @ 4:57 pm
Fully functional for 30 days, then 10 minutes at a time without a license.
Posted Mon 30 Oct 17 @ 5:39 pm
very flexible then....thanx...But i seem to be having problems currently.
1. I have downloaded the latest version of virtual dj home
2. I have enabled early access updates
3. connected my SR 2 controller
The software doesn't seem to provide a pop-up to ask if i want to upgrade my current version to beta version or even detect the SR-2 soundcard.
any help will be appreciated. Thanx
Posted Mon 30 Oct 17 @ 6:48 pm
have you installed the SR2 drivers from pioneer? that would get the audio part sorted.
Posted Mon 30 Oct 17 @ 6:59 pm
yes drivers and all associated software installed. It works with the Serato Dj software that came with the controller
Posted Mon 30 Oct 17 @ 7:12 pm
Damn....Works like a charm..You guys are awesome...Thanx everyone,everything works fine for now.
Posted Mon 30 Oct 17 @ 7:17 pm
How did you do the mapping?
Posted Thu 02 Nov 17 @ 2:02 pm
Posted Thu 02 Nov 17 @ 2:25 pm
Posted Thu 02 Nov 17 @ 3:49 pm
Great job on this manual, thanks. It just makes me like this controller more. In the Pads section, numbers 46, and 47 are reversed. I just signed up for DJCON in NY on Oct. 18th. I've never been before, but they say there will be sales available. I will pick up this unit then, and the Numark DJ2GO2.
Posted Fri 03 Nov 17 @ 12:22 am
Page : [>] [>>]
31%
