Topic: Numark DJ2Go2 - Page: 3
Here it is with the GPD Pocket. The ultimate small gig setup you can literally fit in a handbag. It works absolutely perfectly with VDJ, including full HD video out to an external monitor.
The pocket has:
Windows 10
8gb RAM
128gb Samsung SSD
Micro HDMI out
Long lasting battery so you don't need AC power.
1920x1200 Touchscreen
how long is long lasting?
my tablet gets 2 hrs if i am lucky with windows 10 and VDJ8 running :-(
7 hours ish.
But if juice runs low you can top up with any phone charger and a USB-C cable
The pocket has:
Windows 10
8gb RAM
128gb Samsung SSD
Micro HDMI out
Holy crap!! That is awesome!! I've managed to find a few used ones for around 400/450 bucks. Might have to check um out.
Using them for my gig at the mo with video out. Totally flawless. Wow!
kradcliffe wrote :
7 hours ish.
nice my tablet you can only use USB or charge single port .. this one has multiple USB ports then ?
sorry for all the questions but i been looking for something ultra portable for trips etc...
Is anyone working on a skin for the DJ2Go2.
Where's all your music stored? Presumably you'd have to use an external HDD too, as the storage on the GPD is minimal?
Really no need - the default skin will be great for it
But if you want the kind of setup shown a few posts above, you may want to look into simple skin to be able to read everything...
I think the skin in the picture may be the Fruit skin
Well it depends on your collection but all my music and videos fit on the 128gb SSD
It has both USB 3 and USB-C ports so you can use hubs for external devices if you want to.
Using it with my Surface 3 and a 64gb micro sd card as my plan B.
Can the knobs (volume level, cue) be mapped for other functions when holding down the pad mode button? Waiting on mines to arrive trying to see how I will map to control the bass.
hrdnx wrote :
Does anyone have any suggestions to improve on the wheel?????
(Not touch Sensitive????))
I have this question too!
How is the sound card audio quality?
It's actually very good. I have used it a couple of times in a reasonable sized club for a quick setup and it's perfectly acceptable. Nice and loud too.
Remember you can also use EQ10 as a master effect if you need to tweak the output sound a bit.
Its very very good for the money. Only change I have done to the mapping is to reassign the pitch faders as volume.
Good to know! I have been thinking about buying one but was unsure if it was bedroom quality or gig worthy. I have the first edition (with no built in sound card) which I like alot. Thanks for the info!
i have bought numark dj2go with virtual dj 7 LE
can i upgrade 7 to 8 for free?
Go to My Account above then My licenses if you see a download for VDJ8 LE on that page then you get a free upgrade if not you do not.
If you want to use VDJ 8, why not buy a license for your DJ2GO? It's the cheapest license available.
how much ?
81%
