Topic: Ableton Link - Page: 2
DjHolmiPRO InfinityMember since 2010
I need Ableton Link in VDJ.
Posted Mon 09 Jul 18 @ 6:12 am
djlwoodPRO (OEM)Member since 2012
are we Ableton Link'ed yet? How bout now? I don't want to go back to Traktor. Pretty please. :)
Posted Wed 01 Aug 18 @ 2:55 am
I need Ableton Link also for Lightrider
Posted Tue 18 Sep 18 @ 8:27 am
If you're DJing professionally (your web site tells me you are) then you need a Pro license.
Posted Tue 18 Sep 18 @ 8:49 pm
Another upvote for Ableton Link.
Posted Tue 09 Oct 18 @ 3:36 pm
Same here....... Link please
Posted Sat 27 Oct 18 @ 7:32 am
There are currently 170 apps using Link, including Traktor, Serato, Resolume, Madmapper, Maschine, Reason etc.
Posted Sat 27 Oct 18 @ 4:19 pm
AdionPRO InfinityCTOMember since 2006
Available in Early Access.
To install, go to Options->Extensions and look for the Ableton Link plugin.
Posted Thu 08 Nov 18 @ 4:17 pm
So presumably this works (sync) in both directions - master and slave?
Posted Thu 08 Nov 18 @ 5:28 pm
There is no master or slave in Ableton Link. All links are synced with each other, the one joining a session will be synced with the session at that point.
Posted Thu 08 Nov 18 @ 5:31 pm
Thanks. I'm just using the terms to ascertain whether VDJ can now sync to an incoming clock.
Historically it always needed to be master (ReWire etc).
So once the add-on is installed, how do we use it? [later] OK, found it. It's listed as an effect.
Posted Thu 08 Nov 18 @ 5:35 pm
if you frequently use it you'll probably want a custom button or button on your controller, so then it would be
effect_active "Ableton Link"
Posted Thu 08 Nov 18 @ 5:59 pm
From the Ableton site:
"Please note that on Windows machines, Link requires that you use ASIO audio drivers. Non-ASIO drivers are not supported."
Ah, that'll be why I wasn't getting anywhere just now.
Posted Thu 08 Nov 18 @ 6:13 pm
In Ableton Live it's indeed only available using ASIO, but in VDJ it's still available with WASAPI as well (although stability will vary much more depending on the device and if you're using exclusive mode or not)
Posted Thu 08 Nov 18 @ 6:53 pm
There is no WASAPI in Ableton Live anyway. It's been requested by users, but.....
Posted Thu 08 Nov 18 @ 7:10 pm
s1urfPRO InfinityMember since 2005
I can't find Ableton Link plugin - any pointers?
Posted Sat 10 Nov 18 @ 4:58 pm
It's under Effects, Audio FX
Posted Sat 10 Nov 18 @ 5:02 pm
Hello,
I can't find the plugin on the website or the Software anyone got a link or something?
Best Regards!
Posted Sat 10 Nov 18 @ 5:05 pm
Bronsi98 wrote :
Hello,
Best Regards!
Posted Sun 11 Nov 18 @ 4:10 am
Nice!! Definitely gonna give this a try tonight.
Posted Mon 12 Nov 18 @ 2:35 pm
63%
