DJ Mix Magic Mike wrote :
I am unto find it also. I downloaded for my mac last night and now trying to install in my PC and it just dissapered!!!!
Dev staff wrote :
Bronsi98 wrote :
Hello,
I can't find the plugin on the website or the Software anyone got a link or something?
Best Regards!
Best Regards!
Yes, the link to this plugin appears and disappears. WTF!! I am pissed off.
Posted Tue 19 Mar 19 @ 10:00 pm
There is no link because it was build into the software
So you should be able to finde in under extension - at least I can:
Posted Wed 20 Mar 19 @ 12:14 pm
For the love of all things that give good wubsss, this my friend has solved my Issue with my School project. Why it doesnt work on the master doesnt make since to me. But ill take it. ! thanks
debtman3535 wrote :
I tried enabling Ableton Link on the decks instead of the master and the issue with bpm drift is resolved.
Now, when I make changes with the pitch fader on one deck, the other follows regardless of settings in vdj.
What I may do is program a key that will enable and immediately disable Ableton Link on the master to sync the bpm with the dmx software. While bpm changes won't be automatic, it beats tapping in a bpm all the time.
Posted Fri 17 May 24 @ 2:08 pm
