SBDJ wrote :
, unless this script worked in the previous build.
yes it was working fine in version 7
No 1 a 2 vdj 8
action_deck 1 ? deck 1 leftdeck ? deck 3 leftdeck & deck left select : deck 3 leftdeck ? deck 1 leftdeck & deck left select : deck 1 leftdeck & deck left select : deck 2 rightdeck ? deck 4 rightdeck & deck right select : deck 4 rightdeck ? deck 2 rightdeck & deck right select : deck 2 rightdeck & deck right select
Posted Mon 24 Nov 14 @ 12:09 pm
Nothing is changed on how the above scripts work, so definitely not a regression bug. Please do not continue this here. Open a new topic in the Version 8 Report bug thread (not this one) and we will try to see why this is not working for you. Btw, a similar script is not part of the default mapping of the 4500.
Posted Mon 24 Nov 14 @ 12:30 pm
sclavel wrote :
-Midi clock output (right-click on controller in config window to activate)
-fix problem reading m3u playlists exported by iTunes
-less CPU usage when using complex skins
-effect_select actions with absolute effect number
-global sampler volume also affects video
-fixed potential problem with text transparency on mac
-sampler_group_volume index starts from 1 instead of 0
-get_sampler_bank_id and get_sampler_bank_count actions added
-fix motor scratch lock when deck is cloned
-fix plugins not remembered for more than 2 decks
-video editor allows images to be overlayed
-Some high-dpi fixes for Video Editor
-Fix playback of vdjedit files in some cases
-HID relativetouchslider
-Reverb and loop roll parameters start from 0 instead of center
-Improve selection of comment tag for mp4 files
Greetings and sorry if I cause any discomfort .my question is.... someday return to the clipbank as vdj 7? is the best system for vdj thanks for your attention
Posted Mon 24 Nov 14 @ 10:56 pm
limol wrote :
No 1 a 2 vdj 8
No 1 a 2 vdj 8
Not sure if it will help, but try changing your "deck left select" / "deck right select" to "leftdeck select" / "rightdeck select"
Posted Tue 25 Nov 14 @ 1:59 am
just wondering, in what aspect might you feel that the current sampler is inferior to the clipbank? the current sampler can do so much more!!
Posted Tue 25 Nov 14 @ 2:44 am
I get an abrupt shutdown when i broadcast using shoutcast and the broadcast time has ended.
eg. my broadcast time ends at 2pm est. as soon as it gets to 2pm vdj8 shuts down.
Posted Tue 25 Nov 14 @ 9:58 am
Gentlemen, this is not the forum for this discussion. This is for regression bugs only, thank you.
Posted Tue 25 Nov 14 @ 1:59 pm
sorry for the inconvenience regards
Posted Tue 25 Nov 14 @ 9:36 pm
After customizing my settings in VDJ8 to work with my Numark 4Trak controller I shut down VDJ8, now it refuses to work with my controller. If my 4TRAK is on, it crashes upon opening, if my 4TRAK is off, it will open but once I turn it on, VDJ8 crashes.
Any fixes for this; I have a gig in a week.
Posted Wed 26 Nov 14 @ 12:03 am
I just noticed a clicking/static noise on the sampler.
When the loops starts over and jump to start it comes a noise that sound really loud like a static noise or clicking sound.
I have Never heard this in previous versions !
Using PC
Using PC
Posted Wed 26 Nov 14 @ 4:52 am
Ditto. It seems to appear and disappear randomly, and vary in actual sound.
Sometimes it's just a small glitch. Sometimes it's prominent.
Posted Wed 26 Nov 14 @ 5:24 am
Which pitchQuality setting were you using?
Posted Wed 26 Nov 14 @ 6:20 am
Mine is set to 1
Posted Wed 26 Nov 14 @ 6:48 am
