Forum: Beta Builds Regression Bugs
Topic: BUILD 2059 - Page: 1
-Midi clock output (right-click on controller in config window to activate)
-fix problem reading m3u playlists exported by iTunes
-less CPU usage when using complex skins
-effect_select actions with absolute effect number
-global sampler volume also affects video
-fixed potential problem with text transparency on mac
-sampler_group_volume index starts from 1 instead of 0
-get_sampler_bank_id and get_sampler_bank_count actions added
-fix motor scratch lock when deck is cloned
-fix plugins not remembered for more than 2 decks
-video editor allows images to be overlayed
-Some high-dpi fixes for Video Editor
-Fix playback of vdjedit files in some cases
-HID relativetouchslider
-Reverb and loop roll parameters start from 0 instead of center
-Improve selection of comment tag for mp4 files
Posted Sun 23 Nov 14 @ 10:03 am
MAC Yosemite 10.10.1 / Itunes 12.0.1.26 / VDJ build 2059.884
Still don't work. If I change the comment outside of VDJ (Itunes!), the comment tag will not actualize if i do a reload tags of all files. Also a reload of a single file don't actualize the tag. Look here:
Browser after reload tags (comment should appear after BPM, sorry for bad screenshot)
Comment is right, but must be reload via tag-editor
Is there any workaround for reload all changed files? Or did I missed something?!?
Thanks ;o)
Quote :
Could I get a bit more information as to what this means please.
I've never used ' effect_select ' but guess it puts a effect into a slot without activating it, but it's only a guess.
Further guessing it would be
effect_select 1(slot number) 1 (effect number)
Thanks ;o)
Do you have getCommentsFromTags enabled?
Correct
@Adion:
Yes, getCommentsFromTags is enabled.
VDJ is not recognizing custom mapping for my APC40 after updating to build 2059. It only gives "ignore" or "factory default" as options. It still has my other devices custom mapping (APC20, Mixer & Dicers).
I take it the issue with the controller DB updating is still not sorted. Just checked and still on .868
Keith
For my input on the comments. I am new to VDJ8, but it does not seem like "Reload Tags" in the browser works. I get no feedback that Reload Tags did anything, unlike 7.
In 7 I would see a progress bar and instant changes when done. Now when I reload tags, there is no status and after some delay either my tags do actually update one at a time or I see no change.
Keith
I'm on .884 now and pads seem to be working just fine. It just took so long to update at my end maybe because of my connection. Try again...
Thank you, Thank you, Thank you for midi clock! Looking forward to use VDJ 8 at next gig! So far works like a champ!
Can i use this to sync with a DMX lighting program that accepts midi clock signal or is this just for controllers or other physical midi interfaces??
When playing 2 of the same songs at the same bpm, one deck (left) will play faster and higher pitch than the other deck (right). This problem appeared in 2048. Using Numark NS7II on mac osx mavericks.
new build 2059
after a few mins mixing/scratching, vdj8 freezes for a milisec, after that I have some lag on scratch response.
cloning decks still not fixed (cloned deck is 1/2 beat behind original track), also cloning decks does not copy cue point or loops
scratchwave drift bug still happens with pitch quality 1 or 2
deleting actions crashes VDJ8 on OSX 10.7 (playlists,tracks,folders,midi mappers)
analyzing tracks process takes too much CPU, causing distortion/stutter on OSX 10.7
looking forward to the stanton scs1d tempo fader+platter speed
thank you
found a bug: load a track with a saved loop(at end of track), arm that loop, so the track doesnt stop playing at end, play the track from beggining,then if I touch/hold the vinyl the track jumps right to the armed loop at the end, pitchbend using the platter or even scratch forward(forward spin) its fine,only if I stop/hold the vinyl or backspin the track jumps to the armed loop. I dont think its suppose to work this way...
You can send the clock to another software program, but it will require a utility to act as a virtual MIDI device / router.
On my PC, I use LoopBe (click here).
since this or last build, i have problem with internal Mapping and soundcard Pioneer DDJ SZ
I canĀ“t hear headphone Master output if i change the CUE/Master Poti ???!!!
Mixer question: is this a fake EQ and gain in my skin? i have to less range to power up the bass or another frequenz... i think there was a higher output range bevor
I had sort a many tracks in a folder and make a colour for every song...
Now i wondering about this folder... there are songs with colour and now songs without a colour... what happend?
hi,
I have a Denon HC4500, I add this script:
action_deck 1? 1 deck leftdeck? deck & 3 deck leftdeck left select: deck 3 leftdeck? 1 deck & deck leftdeck left select: deck 1 & deck leftdeck left select: deck 2 rightdeck? 4 deck rightdeck & deck right select: deck 4 rightdeck? rightdeck & deck 2 deck right select: deck 2 rightdeck & deck right select
the tilting of the platinum-selection 2 to 4 is ok
But the rocking of the deck 1 to 3 selection does not work
the HC4500 mapper native and this does not work Scritp (step 1 of tilting a 3)
by keydoard tale with the keyboard shortcut mapper everything works
Deck 1 Works well OK
deck 1 action_deck 1 ? deck 1 leftdeck ? deck 3 leftdeck & deck left select : deck 3 leftdeck ? deck 1 leftdeck & deck left select : deck 1 leftdeck & deck left select : deck 2 rightdeck ? deck 4 rightdeck & deck right select : deck 4 rightdeck ? deck 2 rightdeck & deck right select : deck 2 rightdeck & deck right select
Deck 2 works well OK
deck 2 action_deck 1 ? deck 1 leftdeck ? deck 3 leftdeck & deck left select : deck 3 leftdeck ? deck 1 leftdeck & deck left select : deck 1 leftdeck & deck left select : deck 2 rightdeck ? deck 4 rightdeck & deck right select : deck 4 rightdeck ? deck 2 rightdeck & deck right select : deck 2 rightdeck & deck right select
Your first script has errors in it - for example "1 deck" and deck being spelt incorrectly in various places.
This is not a regression bug however, unless this script worked in the previous build.
OK you got me there. For the life of me, I can't spot an incorrect spelling of 'deck' anywhere in the post.
You're right, I must have imagined that!
61%
