Forum: Beta Builds Regression Bugs
Topic: BUILD 1960 - Page: 1
- new timecodePitchDelay option
- small fixes to the timecode engine
Posted Fri 12 Sep 14 @ 4:47 am
my vdj does not working now, it won't install BUILD 1960..please help !!
After VDJ 1957.804 the software had been updated to 1959.804.
When I restart VDJ following windows appears:
After clicking yes this windows disappear and reappear again and again. When I close it VDJ 1959.804 opens.
Therefore it is not possible to upgrade to never version 1960.
Same problem here
I am also stuck in this cycle. I was running 1959 but it now will not update to 1960.
The popup appears but clicking 'yes' does not apply the update (and the ChangeLog displayed for 1960 is blank).
Same here, manually restarting vdj puts you in the same loop
Same here
yes, there's been a glitch in the update process.
Should be fixed now.
No ........ Still happening here (1959.804) Win 8.1 AMD FX-8350 16GB
Updated this morning , seems to be fine for me . Windows 7 64bit
Try deleting the .ready file in docs/vdj/cache
After doing that, I am now updated to 1960 - although the 1960 ChangeLog still shows nothing.
Can not close application .. followed by a crash . Otherwise it works .
(close solved)
not updating either, also win 8.1
Thank you it works for me.
Cheers Groovin', updates perfectly now, changelog still blank tho' :-)
I feel that dev Team is working so hard and with a lot of pressure.
Thanks
So what's up wit the boot loop
Thanks groov Deleting Ready File worked
Update Error:Keep On the Version 1959.804 System:Windows 8.1 Enterprise GPU:AMD Radeon 7700 RAM:8G HardDisk:seagete
Very Red hahaha......
28%
