Topic: Effects - Wishes & new features - Page: 19
You can use the padfx script for that (see the stems fx pad page for more details)
Hi all,
I'd like to see dual purpose rotary dials that show more than one value please.
An example using the Pro skin where an EQ encoder is being used for both stems and EQ:
It would be nice to see both values depending upon which mode is being adjusted wtih an internal and external curve representing values.
In the third badly hand drawn example below, it shows the MID EQ setting is non zero at a glance whilst the stems adjustment is currently displayed.
that's just a skin thing and can be done right now but only visually
I wish to see crossfader updates / Crossfader fusion like the vocal cut transition which helps to fade the vocal of out going track and bring in the vocal of the in coming track during a scratch after releasing the Jog wheel
explain it better and I could make it.
Sent you message in box about crossfader fushion
Guys can some on teach me how to create Release effects on padfx like "1/2 bt Echo" but only works when I press the pad like a "loop roll"
Is it to much to ask for to get an Equalizer with 30-band for 64, like the old 32 have ?
use a vst
I do that, but why dont VDJ update the old effects that worked well.
And why should we need to use a third party program for eq, it would be a simple task.
Would love to have more effects from earlier days ;)
When i have your attention Loco, is it possible to set/save eq curves on files that loads when song load.
Now I use Poi editor, but not shure if it is saving the setting if i set a cue from start and jumping on a later cue like Cue/Loop 2.
I hope you understand my question.
totally, i'm ok with using vsts BUT improving the basic effects nowadays and adding some new ones would be nice, i prefeer to use stock stuff instead of vst but whatever...
bandpass filter, dials frequency, width, resonance
fx feature wish, I'm not sure where you'd place it on the skin [maybe change custom button 5 into a dial instead of a slider?, top bar?]
A number on the skin that can pick values 1,2,3,4,6,8,12,16 [or accept a val from script]
then an effect mode that when on, effect_active does something like this
effect_active on & wait ourValueAsBeats & effect_active off
I can do this now, maybe it could be a thing for everybody.
[maybe pioneer can rip off my idea and we'll see it as a hardware dial sometime around 2028. Don't act like you don't do this pioneer]
Would be nice to have filter roll like on serato with the filter knob
@Dj SamArch
it exists, it's called 'loop roll'
LocoDog, iluminate me with your wisdom.
It is posible to activate two color fx on one deck at the same time with one knob?
@gvaste yes possible, my remix skin does 4 with one dial,
something like
deck 1 filter & deck 2 fliter
something like
sorry, misunderstood.
i mean using two color fxs at the same time on one deck.
thanks i'll check it out 💖
then not really
but you still can kind of, a virtualfx can control 2 effects on 1 deck with one dial and that can be placed as a colorfx.
It's a little more involved, as regular fx & colorfx have slightly different behaviours.
there is a thread with some info out there ?
i think i can experiment a while.
85%
