Topic: Effects - Wishes & new features - Page: 21
So yes I haven't used the cut effect personally so I can't really give an opionon on that.
It does seem like I can get a large enough reverb with the parameters on the DDJ 1000 if I remember correctly (not just the knob alone as I think that only affects the strength parameter), I think I had trailing source, the room size somewhere >80% and diffusion at ~50% and that seemed to do the job (I don't use it much because I find it a harsh way to transition but that's just me). Similar thing for echo.
Posted Thu 10 Oct 24 @ 1:42 pm
Please add:
- Pitch Down out effect
- Stutter out effect
- Ping- Pong Delay (left-right)
- LFO Filter effect
Posted Sun 22 Dec 24 @ 1:28 pm
If you search the FX area of the extension tab in VDJ, you can find most/all of those.
Posted Sun 22 Dec 24 @ 2:17 pm
Posted Sun 12 Jan 25 @ 3:51 am
