Add them to your database by right clicking on the folder and I bet they show up in the filter.
Posted Tue 20 May 14 @ 1:28 pm
Also, when scanning, music videos show up with a 4 digit bit rate... doubt that is correct.
Posted Tue 20 May 14 @ 1:29 pm
They're in the database already.
Just do me a favor and right click on the folder and add it to the database and then see of they show up in the filter...
Posted Tue 20 May 14 @ 1:34 pm
When I set the filter folder for unscanned tracks, it also shows samples, which then stops me from scanning the folder for bpm's etc.
How can I set the filter folder to just include unscanned audio tracks, or just my drive E, for example.
Posted Tue 20 May 14 @ 1:54 pm
If you don't mind, can we solve my issue first so we don't gum up this thread with multiple issues.
Posted Tue 20 May 14 @ 1:58 pm
did you test it groovin?
Posted Tue 20 May 14 @ 2:21 pm
No problem
Posted Tue 20 May 14 @ 2:33 pm
Of course the tracks should be added to the search db first.
If not, how would VDJ be able to "know" that there are unscanned tracks?
That behaviour hasn't changed from v7 to v8.
You could try this:
isscanned=0 and type=audio or type=video
(or if isscanned doesn't work just use scanned=0)
another way:
isscanned=0 and file path starts with "E:\"
You could try this:
another way:
Posted Wed 21 May 14 @ 3:25 am
Thanks for confirming what we already found out....
Posted Wed 21 May 14 @ 7:16 am
Wow y'all really can complicate things, lmmfao!!
The only difference between this and 8 is that now you can it check a certain folder and just like in 7 YOU HAVE ADD THEM TO THE SEARCH DATABASE.
Posted Wed 21 May 14 @ 7:33 am
Not so easy when the moderators and testers didn't even know... right?
Posted Wed 21 May 14 @ 7:35 am
Well thanks for making us feel better for the HOURS of support we've been putting in.
One small mistake - but thanks!!
Posted Wed 21 May 14 @ 9:08 am
You misunderstood Dan. I was only stating that I was not the ONLY ONE who missed it.
You should know how much I appreciate the efforts, I state it in MANY of my posts.
(Geesh)
(Geesh)
Posted Wed 21 May 14 @ 9:15 am
Ok - maybe i did misunderstand. It's be a long couple of weeks.
I apologise if i gave you the wrong information also....
Posted Wed 21 May 14 @ 9:17 am
It's all good Dan. I appreciate the work of the VDJ team more than you will ever know!
I do this for a living and this has to be right.
Just reported a few Mac issues... another crash, automix issues, video issues, etc...
Posted Wed 21 May 14 @ 9:21 am
Can you try using a filter folder:
Group by Scanned
Does this return better results?
EDIT: No it doesn't - lol
Group by Scanned
Posted Sun 25 May 14 @ 7:41 am
Don't forget that a batch scan of tracks right now is bugged (been confirmed and is with devs hopefully). It gets some BPM's/Beatgrid/Keys wrong that an individual track scan gets right. Just so you know.
Posted Sun 25 May 14 @ 8:38 am
@DJ Craig:
I can confirm this. A scan of all files gets wrong results (tested with mac build 1806).
Hope the fix comes soon ;o)
Posted Sun 25 May 14 @ 1:46 pm
