Hi
As i don´t need to talk anymore about the fadetoblack on volume sliders :),it was already mencioned above,
i´d like to ask the possibility to have a multicam plugin,so we can have at least 3 cam connected to it,guys it
would be very especial with all have seen in this new vid
http://www.youtube.com/watch?v=VlQSSnB4O0k&feature=related
Posted Sun 13 May 12 @ 4:13 pm
I would like to request an app for additional pc to allow a light jockey to see waveforms for active decks. The app should be able to float onto any lighting program and mirror the current wavs that the DJ sees. This would allow DJs to collaborate and intensify the light show with the LJ..
Thank You
Thank You
Posted Wed 23 May 12 @ 2:11 pm
Any decent light jockey worth his salt will tell you he doesn't need waveforms to work his craft, you instinctively feel the music, a lot like a dj reads a room.
Posted Wed 23 May 12 @ 6:59 pm
I would like to see some type of clipbank folder selection for all clips. For instance if I wanted to pull all clips up relating to drink specials, I could have all of them within the 12 selections instead of actually having to do a search and load different ones individually. Then for instance switch to Shadow Dancers and all 12 clips would be Shadow dancers. Maybe some type of menu like the record case. I work in various clubs and having to switch out my clips that are uniquely designed for each club each night is a pain!
Posted Sun 27 May 12 @ 3:19 am
Copy the dll. in your video effects folder to say your desktop or anywhere else on your computer, give it the name say "drinks specials" and copy this process as many times as you want or need.
Now open up vdj and in the video section you will see it populated with your new clipbanks, select the one you want and activate, load the visuals into your new clipbank.
If you are wanting to run random clipbank with these new "banks" you will have to also copy the random clip bank dll. and give it the exact same name, always remember to run the random clipbank dll. first with it's clipbank partner otherwise it will fail to work.
This tutorial I did for one of the guys sometime back may help....
Posted Sun 27 May 12 @ 10:27 am
