Forum: Old versions
Topic: Virtual DJ6 and Numark NS7 (genelar topic) - Page: 15
@ idjsounds
6.0.2 will be available in the software updates section under downloads. Keep checking there.
Posted Wed 26 Aug 09 @ 10:57 am
There will also be announcements in the forums once v6.0.2 is available.
Posted Wed 26 Aug 09 @ 11:57 am
savoryPRO InfinityMember since 2008
Does anyone know if there's any plans for itch to support video?
Posted Wed 26 Aug 09 @ 9:19 pm
I'm pretty sure itch will eventually have that capability. Serato Scratch live runs videos therefore they have the knowledge to implement it inside itch if they want to. Scratch live advertises it as an add on plugin that you have to buy for 200 dollars
Posted Thu 27 Aug 09 @ 9:44 am
I guess Itch is just a watered down version of SSL the same as VDJ console edition?
Posted Thu 27 Aug 09 @ 12:30 pm
only 5 days
Posted Thu 27 Aug 09 @ 1:53 pm
hi all
version 6.02 is up for download
enjoy
Posted Fri 28 Aug 09 @ 3:08 pm
ellicitHome userMember since 2009
so will this support NS7?
Posted Fri 28 Aug 09 @ 3:21 pm
just tried it out, and it does have a mapper for the ns7.
it clearly works a lot better than the 1.4.1 beta version, but it is not perfect yet.
some functions like bleep don't work like they should ( or do in itch)
i can't get the headphone to work
and the delayd start stop function doesn't work.
sync does work but the buttons flashes in a non logical way
i found what appears to be a bug in the config menu, when sliding the sound quality bar from fastest to quality while playing, virtual dj
freezes for 10 seconds or so and then catches up with lost time by playing the song in 400 bpm.
that was just my first impression after 20 minutes of work.
I do use windows 7 so some issues might be os related, but i doubt it
Posted Fri 28 Aug 09 @ 4:17 pm
cant wait until itch2 drops.
Posted Fri 28 Aug 09 @ 4:37 pm
yeah me too,
cause vdj still doesn't work as wel as i had hoped with the ns7.
the two main irritations with itch for me are the bmp sync that frequently is off
and the auto loop function which is off after a few runs ( sometimes) but the loop probelm is probably related to the bmp count
but offcourse i would still see the ns7 work as well with vdj as my hercules rmx.
Posted Fri 28 Aug 09 @ 4:55 pm
I get problems with the sound when i,m scrolling up/down in my favorites
Posted Fri 28 Aug 09 @ 6:07 pm
what a major disappointment for that 6.02 update...1 st no headphone... I mean what is a DJ without headphones!!!...2nd while playing and typing in the search bar i get audio drops for every keystroke..how is that gonna sound when I'm out there tring to please the crowd... its seems like VDJ is going backwards with their updates..I ve been using 5.2 with denons 4500 controller for the longest time without a single glitch. I think of im gonna use my NS7 its gonna be with that basic itch.. lets hope that Itch 2.0 will be the one to make me happy.
Posted Sat 29 Aug 09 @ 1:24 am
well put... Im not a big fan of VDJ sorry I was hoping this would've changed my mind, I guess not.
Posted Sat 29 Aug 09 @ 1:30 am
sbangsPRO InfinityMember since 2004
You can use headphones guys you just need to select it on the sound options.
Posted Sat 29 Aug 09 @ 4:52 pm
RECOMMENDED NS7 CONFIGURATION
RECOMMENDED SYSTEM REQUIREMENTS:
Mac
Core Duo 1.8GHz processor or better
2 GB RAM
OS 10.4.11 or higher
USB 2.0 port
Windows XP
2GB RAM
Service Pack 2 or higher
USB 2.0 port
Windows Vista
2 GB RAM
Service Pack 1 or higher
USB 2.0 port
IMPORTANT: DRIVER INSTALLATION
Before using the NS7 with Numark Cue, you must install the NS7 driver.
Windows:
If you have not already installed ITCH you must install the driver separately.
You can download the latest version of the NS7 driver from HYPERLINK "http://www.numark.com/ns7" http://www.numark.com/ns7
Mac:
To enable your computer to communicate with the NS7 you must first Install the latest build of Itch, this will also install the NS7 midi drivers.
You can download the latest version of Itch from
http://www.serato.com/downloads/itch
STEP 1: SOUND SETUP
Windows:
On the sound options tab please choose the following options:
[Configuration > Sound Setup]
Inputs : None
Outputs : Headphones
Card : Asio
Driver : Numark USB Audio Device
Channels 1/2 main 3/4 Headphones
Press APPLY.
Mac:
Inputs : None
Card : 4/4 Card
Press APPLY.
STEP 2: PERFORMANCE SETTINGS
This step is important for both PC and MAC users.
The performance slider allows a user to set the resources made available to Cue.
Please go to the performance tab [Configuration > Performances]
Please set latency to “Auto” and ensure that “Safemode” and “Overclock” are UNCHECKED
Set the performance slider halfway between “Fastest” and “Best”
Now proceed to test the unit, if you find your system is performing well increase the slider one step towards “Best”
Now retest with the new setting if the unit performs well move the slider closer to “Best” Repeat this until you reach “Best” or you notice performance issues. If you notice a performance issue move the slider back to the last position.
Posted Sat 29 Aug 09 @ 4:54 pm
cstollPRO InfinityMember since 2004
Skyfxl .. ensure the boxes are UNCHECKED or CHECKED ??
Posted Sat 29 Aug 09 @ 5:26 pm
Curses, unchecked.
Would you please do the honors?
Posted Sat 29 Aug 09 @ 7:14 pm
Scrolling is okey now, but the CPU usage is about 17% higher than my HC4500.
20%-27% while playing, 45-70% when loading MP3 and 60%-85% when loading WMA.
Is that normal??
Macbook Pro(Latest) 2.8ghz/4GB DDR3 ram.(XP Pro/Bootcamp)
Used it for about 2 hours on i GIG tonight, it,s great to work with and the sound from NS 7 is fantastic.
I,m a little worried about the CPU usage, do i risk anything running with this CPU usage???
Posted Sat 29 Aug 09 @ 8:57 pm
Will there also be a VV update for the NS7? Or will I need to crossover to VDJ? Sorry if this question has already been asked/answered.
Posted Sat 29 Aug 09 @ 11:04 pm
75%
