Other - Midi Fighter Twister - Layout
MODE 1 - EFFECTS
In this mode you can control 3 Effect Slots and Color FX for Left/Right Decks.
KEY
ROTATE
PUSH
FX Slot 1ENC_1_1/1_4FX Slot 1 Select when in select modeFX Slot 1 On/Off
Long Push : FX Slot 1 select modeENC_1_2/1_3FX Param 1 FX Slot 1 (blue/red led)
FX Param 2 FX Slot 1 (cyan/orange led)
FX Param 1/2 toggleFX Slot 2ENC_2_1/2_4FX Slot 2 Select when in select modeFX Slot 2 On/Off
Long Push : FX Slot 2 select modeENC_2_2/2_3FX Param 1 FX Slot 2 (blue/red led)
FX Param 2 FX Slot 2 (cyan/orange led)
FX Param 1/2 toggleFX Slot 3ENC_3_1/3_4FX Slot 3 Select when in select modeFX Slot 3 On/Off
Long Push : FX Slot 3 select modeENC_3_2/3_3FX Param 1 FX Slot 3 (blue/red led)
FX Param 2 FX Slot 3 (cyan/orange led)
FX Param 1/2 toggleColor FXENC_4_1/4_4Select Color FX when in Select mode
Color FX Select mode toggleENC_4_2/4_3Adjust Color FX
Reset Color FX (mid position)The Top and Bottom side buttons, load or save FX Banks 1 and 2 for the Left/Right Decks as follows.
KEY
PUSH
LONG PUSH
SIDE TOPLoads FX Bank 1
Saves current FXs to FX Bank 1SIDE BOTTOMLoads FX Bank 2
Saves current FXs to FX Bank 2 Mode 2
