Forum: VirtualDJ Plugins
Topic: SBDJ ScrollText - Page: 29
Would Like to have a Tick box in front of each massage to enable me to activate what I need to use for that night at the club, like for instance..
For each Venue set up multiple messages;
Wednesday Beer and Shot specials, Ask the waitress *** Jessy & Janate for details!!!!!
Thrusday Wings & Imported Beer Specials, Ask the Waitress **** Indira & Jenifer for details!!!!!..
Friday Karaoke competition
Lady's Nite Free Martinis from 8pm to 12pm.....and so on....
Hi SBDJ
after upgrading to version 7.0.2 the plugin does not work properly, the video image is completely slow and unstable
can be repaired ?
Scrolltext V2.0 already does this. Right click and enable/disable message. ;-)
P.S. Upgraded to version VDJ 7.2 and not having any problems.
ErikVeejay wrote :
Hi SBDJ
can be repaired ?
I'm sorry, the version of virtual dj is 7.2 x Mac
How do I move the scroll to the bottom of the screen? I keep clicking the Move Down button but it doesn't work
If you're referring to version 1.5.7, the up/down buttons allow you to select which line of text to display.
To move the text up and down, select the "Text" button and use the "Vertical Position" slider.
Crash :(
Thanks for the helpful information you supplied ;)
Hi all,
This is my favourite plug in of them all and gets most use.
I recently changed my pc and downloaded the plugin V2 from the download centre but it appears to be the old version with the 'right click' edit box, rather than a more recent version i have been using for the past few months where there are tabs within the plugin for the different features ...
is there a different download link available for the newer version ?
thanks for any help !
NIKB-DJ
ah, thats great, many thanks
so what i thought was the newer version is actually the old one. It is much more stable. I tend to get a windows crash with the right click version as the pop up window will not always close after editing the text.
i'm off to download it !
NIKB-DJ
That happens with some popup windows in VDJ under certain circumstances - it's often caused by Aero.
Hi,
have you planned an update for support macro in the mac version of the effect or there are limitations from the os x?
Hey,
have an Problem with SBDJ Scrolltext and SBDJ Countdown
both effect do not work since 3 Months
on an old Image it works fine but after some updates both are dead
DirectX9 reinstalled...
C++ 2005,2008,2010 checked
When you say they don't work what do you mean?
if i click on it
it looks like that its not there no information of the plugin
no buttons, nothing
No information at all = plugin failed to load = runtime requirement missing usually.
Working OK here on an up-to-date 8.1 x64 machine.
If you're still having trouble then I can try reuploading ScrollText rebuilt with my current compiler version.
what runtimes i should try to reinstall..
i reinstalled
c++ 2005 (x86)
c++ 2008 (x64)
c++ 2010 (x64)
dx9c
more runtimes need???
there is one thing i do not understand...only two effekts do not work
wihich runtime did they have in common...
The only library I can see that is needed by the current scrolltext build is d3dx9_42.dll.
Could be nothing but two runtimes are at 64 and 2005 your showing as 86, so basically you have 2 @ 64 and another at 32, as I said may be something or nothing or just a typo.
95%
