Hi,
In the Config menu, have you tried to disable the "Safe mode" option?
Posted Mon 31 Mar 08 @ 3:59 pm
yeah, safe mode was one of the first things i tried
Posted Mon 31 Mar 08 @ 5:25 pm
i had the same issue..
here's how i fixed it:
on the powersuply of your laptop, open up the wall-outlet-connector and cut the earth-wire.
or if you don't want to cut power-wires: use an powercord extention which doesn't have earth.
i'm sure that the earth-wire is causing a ground-loop.
this has nothing to do with what version of vdj wether it's a demo or full version
just leave the earth-wire behind.. it worked for me, now i've got crackle/buzzin free audio :)
Posted Fri 04 Apr 08 @ 8:50 am
Do not cut any wires!!!!!! Try purchasing some of these http://www.radioshack.com/sm-buy-the-ground-loop-isolator-on-http-wwwradioshackcom--pi-2062214.html
Posted Fri 04 Apr 08 @ 9:46 am
Hi
I had the same probs with my MK2 plugged into my desktop. I bought a power adaptor from maplins and plugged this into the back of the console (manual says which type you need). This cured it.
On my laptop i get no stati noises so dont need the adaptor.
Odd.
Odd.
Posted Sun 06 Apr 08 @ 11:26 am
Just go to any hardware store and ask for a 3 prong ground adapter(turns a 3 prong into a 2 prong). They only cost few dollars. Put it on on your laptop or desktop.
Posted Tue 08 Apr 08 @ 4:15 pm
If you're using a PC with a three wire cord, an adapter is a good way to fix it. It's long been known that ground loops cause audio problems. Or you could just remover the ground prong from the end of the cord with a pair of pliers. I kid you not. I've done it numerous times.Most PC equipment is double insulated and the power is 12V or +-5V except inside the the power supply, so... not much danger of shock there. Laptops are even safer, since the laptop end is 12-15V. IMHO, spend the money for the adapter if you fell you have to, otherwise, you do what I do.
Posted Wed 09 Apr 08 @ 11:56 am
DO NOT RECOMMEND USERS TO CUT THE EARTH GROUND ON ANY DEVICE!!!!!! THIS IS DANGEROUS!!!
Posted Thu 10 Apr 08 @ 12:17 pm
When will these people stop giving advice out like this.............DON'T DO IT.
Buy yourself the Ground Insulater.
Posted Thu 10 Apr 08 @ 1:03 pm
thanx 4 everybody's help, but i unplugged the charger from my laptop and had nothing plugged into outlets and it was still making that noise.
i ended up jus returning it and started saving money for the torq x-ponent
Posted Sat 12 Apr 08 @ 4:53 pm
