Did u mean this one?
http://www.numark.com/battlepakv4
"A READY-TO-GO DJ SCRATCH SYSTEM THAT PUTS YOU IN CONTROL
No need to look any further when you can get started instantly with the Numark Battle Pack DJ System. This system includes:
1 Numark DM950 mixer
2 Numark TT1625 turntables with cartridges and a pair of slipmats
1 pair of Numark HF125 headphones, and all connecting cables.
The Numark DM950 is a compact, rugged mixer packed with essential features. Includes a replaceable crossfader, 2-band EQ per channel, durable steel construction, a comfortable sloped front panel, 2 phono- and 2 line-level RCA inputs, and a 1/4" mic input
The Numark TT1625 is a direct-drive turntable featuring 10% pitch adjustment, 33 and 45rpm speeds, an aluminum platter, S-shaped tone arm, and dual start/stop controls
Numark HF125 headphones feature flexible, 7-position, independently adjustable padded ear cups; large 40mm mylar speaker drivers; 6' tangle-resistant cord; and padded headband"
Quote from the numark site
Hmmm.. As long it is direct drive n u not gonna use it professional n u getting started, in my view it is ok with those..;) But i don't recommend it for pro use.
Posted Tue 20 Nov 07 @ 5:18 am
cool guys, i will go with TT200. tnx, now what do about this Numark CC1 DJ Mix Cartridge & Stylus
Endorsed by the Scratch Perverts
Plug in silver design
Ideal for general use
18 grams
u have to but for TT200. they dont have the catridge.
18 grams
Posted Tue 20 Nov 07 @ 4:56 pm
You might want to check out the direct drive battle pack spinna points out above. Otherwise those cartridges you mention will suit you just fine.
Posted Tue 20 Nov 07 @ 5:30 pm
awsome, thank for your help
Posted Tue 20 Nov 07 @ 6:15 pm
does direct drive Numark Battle pack work with Maya 44 and timecoded virtual vinyl? ;)
Posted Tue 20 Nov 07 @ 7:00 pm
Yes, it should werk. For timecoded purpose it is important to have the correct SC as in this case maya which have 2 stereo in n 2 stereo out werk as the interface between ur mixer n ur lappy. The TT will be connected via ur mixer.. But just on the side note as ur mixer is not a midi mixer, it will not act as a controller example the crossfader will not react in the software as u moving the faders on the mixer. Hope this helps
Posted Tue 20 Nov 07 @ 8:11 pm
cool
Posted Tue 20 Nov 07 @ 8:38 pm
