Does the Vestax VCI-100 work with virtual dj because it seems to be especially compatible with Traktor
Posted Wed 22 Aug 07 @ 5:48 pm
The vestax works great with VDJ 5 ;)
And it wasnt made for Traktor, it just comes with a light version of Traktor on a cd :)
Posted Wed 22 Aug 07 @ 6:23 pm
I haVE VIRTUAL DJ Home edition 2006 would it work for me or do i need another version?
Posted Wed 22 Aug 07 @ 6:46 pm
oh, you need pro version, Virtual DJ 5.. sorry
But you can upgrade for a discount
Posted Wed 22 Aug 07 @ 6:56 pm
Hello Norway..you say the Vestax VCI-100 works well can you elaborate how to get it to work properly...i am having problems with the scratch and jog features help! thanks
Posted Fri 24 Aug 07 @ 9:30 am
Has the VCI Jog wheel been mapped yet?
I would love to get my hands on a fully mapped VCI-100
Posted Fri 24 Aug 07 @ 11:24 am
Do you guys use VirtualDJ 5 ? The VCI jogwheels should be possilble to map then
Posted Fri 24 Aug 07 @ 12:51 pm
What i'm asking is ; has someone mapped the VC-100 to VDJ5 yet? & where can I get the map/
Posted Fri 24 Aug 07 @ 5:46 pm
Kreg you got the vci-100 ? Then do it by yourself, why you ask others ?
If i had it, that's what i would do.
Posted Fri 24 Aug 07 @ 7:24 pm
You map the VCI like keyboard shortcuts.. its pretty easy.
But there migth come a premade mapper real soon
Posted Fri 24 Aug 07 @ 7:28 pm
Guys it may sound easy but let me say i've been at it now for about 20+ hours with little result..I know what i'm doing but having little success my vci-100 jogs are not moving as nicely as the hercules...is there anyone out there that can help i've got an important gig sunday and need this to work.... Thanks
Posted Sat 25 Aug 07 @ 7:51 am
what value did you set for Jog Wheel , or Stratch Wheel ?
Posted Sat 25 Aug 07 @ 1:07 pm
DJ Cel will know the good settings.. will ask him
Posted Sat 25 Aug 07 @ 2:34 pm
Whew! Well I had a go at doing some mappings for the jog wheels but I must be thick or something lol What a perfect partnership VDJ and the VCI! Would someone please post a mapping? Please.
Posted Sat 25 Aug 07 @ 9:34 pm
64 is a good value for the jog wheels.
Posted Sat 25 Aug 07 @ 9:38 pm
for the jogs is the a value of 40 a wohle round like the turntables on your screen ;-)
Posted Sat 25 Aug 07 @ 9:44 pm
I'm really sorry but could you just explain (in idiot terms) what the procedure is fro mapping the jog wheels to scratch using the metal platter and pitch bend whilst touching the glass?
Really really appreciate any help.
B
B
Posted Sat 25 Aug 07 @ 9:53 pm
at the moment i had the glasses not configured, only the jogs... with the glasses seems not to be so easy to configure.
please wait a moment, because i am currently mixing a cd for a girlfriend... in round about 40 minutes you will know more... when i start virtualdj, my other software stops playing ;-)
Posted Sat 25 Aug 07 @ 9:56 pm
lol no worries! I know what it's like when you're trying to throw down a mix! lol
Posted Sat 25 Aug 07 @ 9:57 pm
i hope, i can help. thats my configure of my jogs...
i've said 40 is a good value, i am sorry, its 10.... but try it on you system. i dont know if there a some difference by using different systems..
this configuration works fine for me. if i turn the jogs one round (360 degrees), the the turntables on the screen will turn 360 degrees too..
thats a good feeling ;-)
Posted Sat 25 Aug 07 @ 10:47 pm
