Topic: cdg decoder - Page: 1
Help plez...My cdg files from zip files is not loading in VDJ5, the mp3 does but no video???? is there a cdg decoder....I've been searching the past hour and 1/2 in the forum...and have gone thru vdj5 manual but no luck....
thanks much
GREAT JOB with VDJ5...so much better than PCDJ!!!! you guys rock!!!!!!!!!
MARK ALLEN
Posted Wed 22 Aug 07 @ 1:16 am
I have the same problem,I can play any of my vob files,mp3's play fine but many of my mp3+g zip files will only play the audio portion,several work ok with the graphics showing ok.These are the same files that have worked in every update from 3.2 to 4.3.
I just love all the improvements made on version 5.0,I do wish my automix button worked for a "mix now " function.
Thank you everyone for all your hard work and nice job on the new website it looks great.
Dan
I agree (mix now) button is needed.......
Thanks
MARK
but i still LOVE VDJ5..this would be a plus to have in next update.........
What changed from v4.3 to 5.0 as far as reading zipped files,Is it a different codec? If so would it be possible to extract this from 4.3 and install it in to 5.0?I'm looking for some last ditch answers before I uninstall v5 and have to go back to 4.3.It appears the majority of my zipped mp3+g files will only play the audio portion.As I stated above these files have always worked from v3.2 up to 4.3 and they work with Sax & Dotty.Help!!! I love version 5 and don't want to go back. Dan
UPDATE:I uninstalled V5.0 and did a fresh install,retried same problem.Next I uninstalled V5.0 and Installed a full version of 4.3 now all my zipped files work perfectly. Dan
in 4.3 and earlier you could add under (extension) cdg (Decoder) Karaoke cdg/zip decoder on the (Codecs tab) under settings for vd 4.3 we don't have that for VDJ5
SMILE tag you're it
MARK
UPDATE:I uninstalled V5.0 and did a fresh install,retried same problem.Next I uninstalled V5.0 and Installed a full version of 4.3 now all my zipped files work perfectly. Dan....
was there a copy of 4.3 on your system.. before you did a fresh installed vdj5
MARK
VDJ 5 have a different ZIP decoder to compensate for the fact that Vista sees Zip files as folders.
But, during beta test - noone mentioned anything about karaoke not working. So hopefully someone can post the solution real soon...
(I'm sorry, I dont have any karaokefiles)
No problem..I'm very HAPPY w/ VDJ and sure there is a cure or solution coming soon....unless there is something I'm Missing.......
Have a FANTASTIC NIGHT
DJMAZ/MARK ALLEN
Thanks Norway.
doyou think it would be possible to just add the old decoder into a file?I'm not a computer genius so if that was a dumb statement and your still laughing I'll understand. Dan
PS @Mark LOL
Pirate at 40 wrote :
Thanks Norway.
PS @Mark LOL
If you are on vista, the old one would not work I think.. as Vista makes VDJ see Zip files as folders.
But I'll check into the karaoke thing ...
I'm using Windows XP sp2
SAME HERE WINDOWS XP PRO.....NO PROBLEMS WITH VDJ4.3
THANKS FOR POSTS!!! AND TRYING TO RESOLVE
DJMAZ/MARK ALLEN
Mark what video card are you using? My Gig laptop has a ATI 256meg.
I tried version 5 on my home desktop with an NVIDIA card and my inop. zip files appear to work. Dan
Hmm, I'm only seeing a problem with a few tracks. Perhaps they are just corrupted in my case.
- THOSE HAVING PROBLEMS WITH ZIP
Can you please try this :
1) Unzip the file
2) Rezip using WINDOWS zip decoder
does it work now ?
Didn't work for me. However I'm uploading one of my files that doesn't work so maybe somebody else will test it. Then I will know if mine are just bad files or what.
http://www.sendspace.com/file/4vl80i
Here we are. I really think mine is just corrupted though because it's only like 3 out of 100 that I checked. I don't have 4.3 installed anymore so I can't check it to see if it works there either. At first I thought it had to do with the little glitches at the beginning but that's not it either as I found another one like that and it worked.
VDJ sees that Zip as a file, it auto opens my video window...
But it doent display the text
maybe someone can try the same file in VDJ 4.3 ?
57%
