Is it possible to convert midi notes from lets say the " Trigger Finger " to a keyboard key.
example:
Make one of the push buttons on my midi device = the "shift" button on my keyboard. Or better yet a macro like ctrl & p.
Any way of doing this?
thankya
example:
thankya
Posted Sat 10 Feb 07 @ 10:22 am
not as standard with VDJ i dont think but there are several MIDI tools that can generate MIDI notes from a computer keyboard and other MIDI widgets floating about that merge MIDI streams etc, have a look and see what you can find :D
Posted Sat 10 Feb 07 @ 11:22 am
just trying to this
"but there are several MIDI tools that can generate MIDI notes from a computer keyboard"
but backwards
but backwards
Posted Sat 10 Feb 07 @ 12:21 pm
Know of any midi formus to get some detail info? There has to be a way to do this.
Posted Sun 11 Feb 07 @ 8:59 am
The best software i know is this http://www.bome.com/midi/translator/
Forum is also available.
Posted Mon 12 Feb 07 @ 12:01 am
thanks for the info, just downloaded the demo see if it can do what i need. It has some other features aswell like timed functions. So lets say you wanted to make a video transition delay for 4 seconds you can do it. That way your not rushing to hit buttons. You can concentrate more on mixing.
Posted Mon 12 Feb 07 @ 3:14 am
