skyfxl wrote :
Okay but please keep us informed on the subject.
ok they are aware of this issue and are looking into it and they will do their best to solve it
as you can see from the history of virtual dj they have kept many development promises
and it affects some important controlers which are very useful
nough said.
nough said.
Posted Thu 10 May 07 @ 4:39 pm
Hi,
Please add me to the list of those most interested in news on this.
The A&H Xone 3D or the Vestax VCi-100 are my top favored choices at the moment... but I'm hesitant to do anything unless I know the system will work with the DJ software as a system: plug and play.
The XP 10s seem to be nice controllers... but I really need a mixer.
I suppose the Ecler NUO4 mixer with a pair of Numark iCDX would be another option.
Thanks.
Thanks.
Posted Mon 28 May 07 @ 7:12 am
anybody read this yet?
https://virtualdj.com/forums/70849/Hardware_Technical_Support/Xone_3d_Jog_Wheel_Fix_(WORKING).html
Don't have one so no idea how well it works, but probably worth a go if you've got one.
Posted Mon 28 May 07 @ 11:42 am
hola que alquien me eche un cable con la allen & heath xone 3d como configurar los jog y tambien la tarjeta con la latencya gracias de ante mano veo que todos tenemos el mismo problema
Posted Wed 11 Jul 07 @ 8:03 pm
For spanish language go here:
Para la lengua española ir aquí:
https://virtualdj.com/forums/12/Spanish_Forum.html
Posted Wed 11 Jul 07 @ 10:52 pm
Will VDJ Version 4.4 be able to support the Xone3d?
Posted Fri 27 Jul 07 @ 1:07 pm
Only team knows that, make a ticket:
https://virtualdj.com/contact/
Posted Fri 27 Jul 07 @ 3:28 pm
