Forum: Music discussion
Topic: DJ MIXING : basic - advanced - pro - Page: 8
P.L.U.R. from CROATIA 2 ALL VDJ-s!!!!!!
Dj Persue
I am make cds for my friends
i would like couple codes for virtual dj send to my e mail address
this program rocks it is hot well hot
its like the think in my town jamaica
send back to my mail soon.
hey dj in norway i had another question :
what are the difirence between the diferent VDJ programs .......theres diferent ones like home edition professional edition and what not .....what are the diferences and which would be best for me ........?
whats the currency.....euros??? i need to know the price in dollars
another question .....what is better a laptop or a desktop???? considering that i'm gonna have other programs for remixing and producing.....big programs.......and lots of music.......
last one: i'm gonna get a mixer and turntable (1) and a maya44 soundcard
the external one has outputs and inputs 8 in total, the internal only has 4 .....whats the diff ???
Hi everybody!
I just got a copy myself of virtual Dj!And i would like a few tips off you masters out there if ya wouldn't mind!
Regards,
DJlilg!
Hi, I need a big advice ! Well i was used to the dj console ! but u know for a while u want to go little higher ! my problem is somtimes symchro and crossefaer are driving me crazyyyyyyyyyyy !
ok synchro i don 't find any problem puting them athe same beat with the synchro button !
but the problem , in my new smx 301 is that the sound comes too strong on the song a from the song b !
song a is playing well .... cross fade song b comes too strooooooong ! well should i put the bass down for every transition between songs ? i m really tired of this thing becuase it doesn t sound perfect in my hear ! ! and being perfectionist make it worse ! any advice ? please ! really need it ! I waaaaanna learn ! how do u do guys your transition ? thks
Sonia Or Dj angel ;)
DONT USE THE CROSSFADER!!
My mixing strategy:
the song is playing on deck 1. its volume is on max. On deck 2: I set the bass to 0% . Its volume is on 0% or 30% I start to play the song on deck 2. then I gradually increase its volume to 100%. so both decks are on 100%. While I decrease the volume of deck 1, i increase the bass of deck 2 slowly
I dont use the beatlock, just the jog wheels to nudge!
and disable timestretch!!!
Totyo
That pic of the splitter thingy for headphones . were can i get 1
@DJ Angels, is your crossfader set to cut? It needs to be on smooth or full (forget what it's called in VDJ). That should help your transitions. Also auto gain will help if your problem is being caused by the gain on the incoming deck being higher. Lastly, eq's are a dj's best friend. Swapping bass from the outgoing and the incoming song makes for a very smooth transition.
@jmez...if you're in the US Radio Shack carries them. It's called a Y splitter.
Thanks for answers guys, well the thing is I mix with a mixer so I'm not sure if I change the options of the crossfader in vdj will help...may be I should try...
Since few days, I praticed with a low bass as u said it works pefectly well thank u very much :)
depending on the brand and model of mixer you have you might have a crossfader adjustment on the mixer to adjust how you want the crossfader to react (either cut or full)
Best Regards
DJ White Devil
ko let me come to the point.
i know every thing about the dj or the dj's.in your virtual dj playr version 3.0 in dont know one thing:
if i want to play the next song from between how i cn play it,like i want the song to be playing and the people to be hearing them but i want the different song to be hearing in the dj headphone.please give me the suggession.......................
they dont ship a timecoded vynil to brazil do they .....i'd have to travel to get it .....
HI.my name is martin,i like djying and im new in using virtual dj,so please send me some tips of how to mix to songs because thats my problem i always encounter.Thanks
32%
