Forum: Music discussion
Topic: DJ MIXING : basic - advanced - pro - Page: 7
i have the one that you put that connects to the sound card in the picture
but it doesnt split stereo.......it just makes one input into 2 outputs ......how would that work
does it have to be a stereo splitter????
and the headphones would be mono ......right????
you need a stereo SPLITTER, that splits the right and left signal... not a duplicator of the output.
And yes, this solution makes both master out, and headphone, mono.....
You can always get an external usb 5.1 soundcard cheep, and have stereo out for both master and headphone :)
hummm....................interesting
i'm seying whats best and sheapest here.........and my hats off to you guys answered all my questions as complicated as they may seem you gave a perfect explanation to all of them ...
thank a lot for all your support
could i use hercules and get a turntable.......and use hercules as a mixer.....and soundcard??
plug in the turntable into hercules and use it as a mixer...
yes, you can :)
With the new Hercules MK2 console
so i wouldnt have to get a mixer or a soundcard ..........just use the hercules MK2 as a soundcard and mixer ,...............nice
yes...
But, its a MIDI controller that works like a mixer... in "software mode".
It controls the VDJ software, the same way a keyboard and mouse would.
Getting an external mixer with hardware EQ's and real knobs/sliders, would of course be better quality.
But the Hercules MK2 is a good start, and good for practice... .and u can always expand to real turntable and real mixer later, and connect that to the console.
It is a great soundcard
Hy!
I just started using vdj and it would be cool if you guys could write me some tips how to use this program.I use vdj for playing songs one after a nother.But I think,there are way more options than that,and it would be good if you would write theese things.My friend is having a birthday party and would like to use vdj for mixing the music,and to throw a BIG party!
Please write me how you use vdj and what do you do when the song is playing.
thx!
write me some tips how to mix 2 songs,when the music is playing which effects do you use.The best option would be to send me a record of your mixes.thx
--@--.-- you send me some music send it to this email adress
Moderated by Lady Cameron
Sorry Extec no email address is allowed from a demo user
Just search the Forum for various questions and answers that you have. Also check the first part of this post for some good mixing tips.
MS
dj in norway i've been thinking and i wanted to get a turntable i'm its better and cheaper to get a maya44 a mixer and a turntable than a hercules MK2 and truntable.........
a hercules is $250 and a maya44 and mixer just go to $200 if i get a 100 dollar mixer.......
and its better quality so i guess i'll get that
oye como descargar effet
@tatto : Comprar la programma :)
@heman : Maya (or other asio dual soundcard) + real mixer is better than hercules :)
If you can get that for a lower price than Hercules, go for that .... :)
okay .....will do
Tx.
dj_rave_d in the mix
in a dj but i so speacking portuguese, i dont understand inglish...!!!!
fala portugues???? dahh onde vc ?
28%
