Forum: Music discussion
Topic: The Ultimate Guide to Broadcasting With Virtual Dj - Page: 5
Hi everybody yesterday i connected to this radio server for my dayly session but what's weird is that the broadcast server shows me to be 'up and private' instead of 'up and public'.
It's a shoutcast server and with winamp it seems to be up and public.
Why what's going on?
Can i fix it?
Thanks
DJ @XiL
www.fusionradio.biz
djaxil@hotmail.com
which version are you using?
VDJ 3.i dont know the latest
:D
ok , do you have a router and have you followed the steps in the guide to forward ports through your firewall and router (if you have one)
remember you need for unblock and forward port 8000 and 8001
yep u see i dont have a router a simple usb moderm and i use a different port 9936 if i remember right.
i can broascast the problem is like i say it runs it as a private session instead of a public one like in a winamp broadcast.
to be listed in the shoutcast directory if your using the shoutcast server externaly you must use port 8000
please note if you using the internal , shoutcast plugin in vdj it wont list in the directory either , but it can broadcast to a external public server if you choose the external server option
ok thanks how do i do that?
look at the first page of this topic its all explained in the guide :)
Thanks m8
How can I broadcast on Home Edition?
Well, maybe broadcast is the wrong choice of words. I would like to play music and talk over it but save it to a file (later for cd). Thanks
I hit the broadcast and it says I need a plug in
choose the record mp3 option
use mic + main
Completely new to this program... (home edition)
can't even find the broadcast config from the first page
or reference in the pdf help file...
The encoder box is empty and i cant find it in the VDJ folder i have the MK2. i think it is whats stopping me from broadcasting. anyone know where i can download this encoder?
Hello all...
Well, I have read through all 7 pages of this thread and can't seem to find the answer I am looking for.
Is anyone having any success broadcasting to Live 365? I have a station there but cannot get VDJ to broadcast and can't figure out why. I have followed the instructions in the beginning of the post for setting up my broadcast but seem to get lost where I begin broadcasting to Live 365. Is there a step by step somewhere that I don't know about? Any help that anyone would be willing to offer would be great.
Thanks so much...
Wayne Theurer
have you enabled the server on their end?
in your acount you need to turn on your server acess
Yes, it says that my Live365.com server is on, and gives me this port information: 216.235.91.35:20298
When I type this information into VDJ's recording configure, it says that I am connected and broadcasting to Live365, but Live365 shows off the air.
Hello, I am new here.
Ok so I read all this, and I take it, I cannot broadcast unless I have a router? Because I don't at the moment. I have been using listen2myradio.com but I don't get enough listeners.
Is that it? I got the same problem like the other person. I want others to listen but when they go to the url 869.0044 bla bla....VDJ.mp3 it shows page not found.
I'm completely confused if there is an option without a router...
Anyone else experiening problems with shoutcast meta-data updates (titles)? For example, every 3rd song is updated... I think it's buggy (Virtual DJ 5.2)
68%
