Forum: Music discussion
Topic: The Ultimate Guide to Broadcasting With Virtual Dj - Page: 4
a friend of mine has the pro version. how can i do it directly from the virtual dj to push a button when i want to talk and the music decreases?
you need it your not allowed to use his copy
enable talk over on the console soft and when you turn the mic on by pressing the button it is reduced
i hope to see you as a pro user soon
we want to broadcast from my friends computer, he doesn't own hercules and he wants to do it directly from vdj so please someone answer my simple question. thanks
he should use his acount to ask then..
why you just can't answer my question?
anyone please?
how do u broadcast?
Can one use Mac Virtual DJ for broadcasting too?
billy_44 wrote :
how do u broadcast?
check page one of this guide
yes its all the same setup :)
Sky
I have opened ports in windows firewall and I just have a USB modem.
When I try to broadcast it says "Error" "can't listen on port 8000"
Any ideas what I can do next.
who is your carrier? they can block ports on their end too
for example aol ban server ports unless you request them.
You may have to purchase a modem/router, I am not sure if usb modems can be configured as your requirements.
Mike
Can anyone help me , i am trying to broadcast using mk2 console and virtual dj. I try to use Shoutcast at which point i see that a Encoder is required. I don't know what should used in the Encoder section. I am running through a netgear modem router on a broadband connection, i see everyone mentioning port openeing, but i am assuming this is only used for streaming to a server which i do not want to do. Would appreciate some help
i have downloaded the encoder and saved it to the path file you saved it but i can't seem to find it when iam looking in virtual dj folder, and nothing goes into my encoder section
do you think i need winrar to open the encoder as it comes as a zipped folder
yes extract that and copy the lame.dll to the virtualdj program folder
I have put the .dll into virtual dj and that has changed the end of the link to virtual dj.mp3 ,but i still cannot log to the link is there anything i need to be changing on my router and if so does it affect my day to day normal use of the internet ?
look in the config and forward ports 8000 and 8001
do the same in the firewall :)
54%
