Topic: Anyone have simple instructions for BCD2000/headphones
I have read every forum I can find. Anyone have any simple instructions on getting the headphones to work in the BCD2000 like a normal mixer....like pre-listen the next song.
Thanks.
This thing and VDJ is driving me crazy.
Posted Wed 20 Sep 06 @ 4:06 am
What is this....I see no BCD2000 info
you want to connect cd players or something else? I mean, don't you wanna use it as a midi controller for vdj? please be more explicit in the way you want to work with. I use it with tcvs in asio mode and the midi controller with headphones as well .
If you want to prelisten from the BCD2000, this means that you have to use it as sound card and particularly as ASIO sound card. You will face a few problems which VDJ Team is working on right now. So far, this blog http://www.virtualdj.com/blog/moramax will help you but remember it is still very unstable, so if you get it working i would suggest you to mark this as a system restore point.
@djdad
I don't think bcd is very unstable, I've been mixing videos about 8 hours in asio mode and I hadn't have any problem, perhaps there are still some problems of compatibility with certain motherboards but dev team is working on fixing this bug.
@manquin_dj
As long as you don't touch some things, yes it's stable. But i have a few DON'T TOUCH things on my mind when i say unstable. And actually when i say unstable, i mean the BCD not the VDJ, which is truelly amazing.
Thanks guys....I am halfway there. I can only pre-listen to the B deck.
what skin are you using?
please select this standard skin:
VirtualDJ: Internal mixer
you can see in the center of the screen near level v-umeter 2 little command buttons called pfl (one blue and the other red).
to switch the prelisten you have to push that buttons:
push button left(blue): to prelisten on left deck
push button right(red): to prelisten on right deck
if you want you can also assign a midi shortcuts to make this from bcd.
Many Thanks to you all.........BCD2000 finally works like a mixer.
It's a start !
sorry I did not see this trhead before, but I am happy that some user that now how to fix the problem are helping to somebody else to do it, that is making this comunity very helpfull.
regards
Dj Quintana
