Forum: Old versions
Topic: Behringer BCD2000 shortcuts XML - Page: 6
I NEED SOME HELP!
I successfully assigned everything in MIDI Translator and the BCD2000.
Everything's fine..
There is just one major problem.
It crashes everytime like after 1 or 2 minutes while mixing/playing a song.
The music just stops playing or shall I say it locks up.
Any solutions for this?
VDJ 4... .soon to be released, and has native support for BCD2000.. no need for midi translator anymore;)
it'll take a while though...
but anyways,
I just want to practice. Any suggestions why it locks up?
dj-in-norway, any tentative dates when it will be released?
@aaronpollard
Are you mixing on a Laptop?
Try switching off wireless lan, this worked for me ;)
yeah, I DJ with a Laptop... it locks up using ASIO.. using "Antonio's" instructions in macfruits.com..
I'll try that...
WORKED!
excellent!
thanks man
hmmm
can anyone pleaaase explain what does the wireless have to do with the ASIO Drivers?
wireless interrupts many things.. if shared IRQ.. unfortunately...
So, XP asign both to irq 9 usually... and by stopping Wireless you can get far better performance
@dj-in-norway
any dates for the release of the new VDJ that supports BCD2000?
the date is not 100% set... but it will be very soon.
We are in the final beta testing, and things look good.
It will be released as soon as everything works flawless:)
any news on date yet??
Hello frndz can any body plz tell me that is virtual DJ compatible with the Behringer BCD2000 plz plz plz .........
