Forum: VirtualDJ Skins
Topic: !!! advanged default !!! - Page: 3
yes it is, I was speaking of the actual words ACTIVE and DEFAULT, but it is still good.
Thanks for the update of the picture but no update in the skin download area...
...Is necessary a virtual dj team update?
Hello djjb, when you have time please try the new mix station
http://www.virtualdj.com/addons/skin.html?id=53
I see some good button for the video panel, I think it's good in your skin to change the 4 transition button draw because it's possible to change the type of transition different to the draw.
The numeber 1-2-3-4 it's good idea.
Write open/close on the button to open & close the video window.
Insert the PAR button to change the FX plugin type via button.
Bye & really thanks in advance
It looks good, will you make a wide screen version too?
Just an opinion: gain as medium size slider - not a good idea. Especially when the same size as the volume level.
For first I wanna finish the version 1024x768 and in the future I will start to modify the screen size.
There are 3 possible configurations for the the gain and volume slider, only volume, only gain and both.
yes
Wel guys..
I asked the team to delete all my "advanged default" skins from the download page.
I have a totaly updated zipfile with all A.default. skins in it. all 1024-768 pxl. soon i will change this.
Maybe some 1280-1024 pxl or 1280-768 pxl.
it's just the mather what YOU want !..
see ya arround..
john
I don't need your skin cioce..
You have made great changes on the adv.def. skin. I'm sure somebody like it.
But you are running away with my ideas..and I don't like that. :-(
I don't wanna be a ass%&*#.. but i have to say what's in my head.
john
Ok djjb, I understand, have a good work for new skin resolution. ;-)))
thanx...
sorry
good skin
new update today uploaded.
activated
last update 26-06-06.
i changed the loop-function.
loop - and +
replaced the track-time near the author/title.
even the clone and delete buttons are in there.
just see it yourself.
hope you like it.
john
something has going verry wrong with the last update..
so i have to change this.
update comming soon..
