Forum: VirtualDJ Skins
Topic: !!! advanged default !!! - Page: 2
bellow the automix-button is a pannel-button. normal or console..
i hope this works.
Make Attention because the automix button have two different function with left click (automix now) or right click (automix stay on and load track from playlist), I think you can insert onle little long orizontal button (name normal or console) in the middle down of FX and up to the automix botton with the same length.
Thanks a lot, I can only wait the update of your fantastic skin.
Bye ;-)
Ps I like DJ John crazy modify .-))))
Very nice work!!!
that's good to read..
i'm happy..
John,
I'm glad you got the updates done. Looks good.
I cannot find the update on the SKIN menu, is it there?
not yet...i'm trying it out now. searchin' for bugs..
still not updated..!?
posted again today.
Don't worry the team have all your last uploaded versions so just wait
skin activated
Thanks Djjb for the update of the skin.
Can you explain me what is the function of MT = ON or OFF near the minimize button?
MT is master tempo
i changed the collors and the "select" - buttons
it's in my blog.
Black is a good idea.
I see the tooltip "show remixing commands" on the console FX setting in the panel for the setup of the skin, is this a bug? But in any case this work fine.
Can you please insert the MIC level bar?
I think the time to start and to end font is little small, do you think it's possible to use the BOLD in the font?
i see what i can do...
I see you have ACTIVE for the deck currently playing and DEFAULT for the other deck, maybe you should change DEFAULT to read HEADPHONES or MONITOR??
This may be more useful to new users of VDJ.
it's the same as the original default skin , isn't it ?....
68%
