Topic: Mapping hot cues
I’m trying to map the hot cues to go back to the beginning of the track and not automatically start back playing the track. I’ve used multiple AI and forums to get the correct script, and they’ve all been in agreement about what to type. However, nothing has worked so far. For example, goto 0 & pause is supposed to work, but no luck so far. Thanks!
Posted Sat 01 Nov 25 @ 12:32 am
goto 0% & pause
You missed the %
Thanks I’ll try that
goto 0 & pause works here, Track stops at the beginning, but probably you meant something else...
Perhaps you just need to se the setting HotcueMode to Stutter ?
