Hello,
When I open VirtualDJ Remote on my smartphone or tablet, it immediately shuts down VirtualDJ on my PC.
Since I haven't used VirtualDJ Remote for a while, I don't know if the bug is due to one of the latest versions of VDJ or VDJ Remote.
My computer setup:
- Victus PC, Windows 11
- VDJ (EA) b8726
My smartphone setup:
- Samsung A52
- Android 14
(I also tested it with a tablet running Android 13 and it also crashes the PC)
I hope this bug can be fixed soon.
Thanks in advance to the developers and have a great day everyone,
My computer setup:
- VDJ (EA) b8726
- Samsung A52
- Android 14
Posted Wed 03 Sep 25 @ 11:16 am
Can you try to clear the app data to see if that helps?
Posted Wed 03 Sep 25 @ 11:21 am
Same thing.
By clearing data and even uninstalling and reinstalling the app.
Posted Wed 03 Sep 25 @ 11:35 am
So it is the VirtualDJ on PC that crashes and not the android app. Can you confirm again this point?
Posted Wed 03 Sep 25 @ 1:06 pm
Yes, exactly.
As soon as I close the app on my smartphone, I can restart VDJ on my PC and it works normally again.
Posted Wed 03 Sep 25 @ 1:24 pm
I think you use the early access updates. Go back to BUILD 8678. that will help
Posted Wed 03 Sep 25 @ 1:25 pm
I'm using the latest public build on my DJ laptop and it's working fine. Must just be an issue with the current EA build.
You can roll back here: https://www.virtualdj.com/download/build.html
Posted Wed 03 Sep 25 @ 1:40 pm
Fixed in 8729
Posted Wed 03 Sep 25 @ 1:57 pm
VDJ Developers…
Best team ever!
It works!
(both with my smartphone running Android 14 and my tablet running Android 13)
Best team ever!
It works!
Posted Wed 03 Sep 25 @ 2:32 pm
Adion wrote :
Fixed in 8729
not here.
No crash, but nothing happens on the app. and no controlls.
Posted Wed 03 Sep 25 @ 3:02 pm
The remote doesn't show "Waiting for VirtualDJ connection" ?
And you followed https://virtualdj.com/manuals/virtualdj/vdjremote/remotesetup.html to connect it?
Posted Wed 03 Sep 25 @ 4:18 pm
the app starts but has no communication with the PC. all faders are at 0. the songpos is visible but not working. I can switch panels.
Posted Wed 03 Sep 25 @ 5:52 pm
Just tested on 8729 here and all working as normal.
Posted Wed 03 Sep 25 @ 6:14 pm
still nothing.
The app is working but the visuals are not.
Posted Sat 06 Sep 25 @ 7:31 am
Did you try to clear app data?
Posted Sat 06 Sep 25 @ 8:48 am
After deleting my phone in vdj and reconnect it was ok.
tried another laptop and also worked fine. So I think it"s ok now.
thnx
thnx
Posted Sat 06 Sep 25 @ 6:01 pm
